Here is a list of all the postings Roger B has made in our forums. Click on a thread name to jump to the thread.
Thread: Combined Lathe & Mill |
23/11/2017 11:39:10 |
I started out milling with a vertical slide on the lathe. This worked but travel was limited and setting up was not aided by gravity. Like you I do not have space for a separate mill so I added a milling head. This is certainly a compromise and is not as rigid as a true milling machine, but by removing the lathe chuck and tailstock it has quite reasonable travel for my use. An up to date Hobbymat and TECO mill are available from Pro Machine Tools. Best regards Roger
Thread: My first lathe |
04/10/2017 11:11:00 |
The first lathe decision is always difficult. Buy the biggest/best you can afford is one way of looking at it. The other thought is buy something that will be sufficient for what you want to start with. If it is not too expensive it won't hurt so much the first time you take a lump out of the bed or cross slide Best regards Roger |
04/10/2017 07:23:31 |
I started out with one of the generic minilathes and latter added a milling slide designed for the smaller Clarke lathe by drilling and tapping 4 holes in the cross slide. There are a couple of pictures in my album milling slide. What are you intending to make on this lathe?
Best regards
Roger |
Thread: Warco or Hobbymat MD65 |
27/09/2017 07:13:05 |
I started out with an Einhell Minilathe and then moved on to a Hobbymat with milling head. The Hobbymat is more rigid and better finished but is slightly smaller. The headstock is MT2 and around 12mm bore. The Minilathe has MT3 and around 19mm bore. The low speed kit for the Hobbymat is still available but the tumbler reverse if you want it would have to be found secondhand. Other accessories may also be harder to find. What are you intending to make, this my help guide your decision?$ Best regards Roger |
