Member postings for Robin
Here is a list of all the postings Robin has made in our forums. Click on a thread name to jump to the thread.
Thread: Metal Suppliers
11/07/2021 11:08:53
Another vote for Rapid Metals. Free delivery with DHL if you spend enough and they will sell you little bits without cost penalties. Watch out for their 4mm sheet though, it's bent.
Thread: Chinese drip feed oilers
11/07/2021 10:46:30
Of course, Old Muggin's here has a bag full of them frown
They need a bit of work in the throttle if you want it to shut off.
The top spring thing that uncovers the fill hole and holds the drip adjust wherever you left it, is a steel stamping with sharp edges so nothing about it is easy.
The screw thread at the bottom was not something I had in my collection of taps and dies.
What about those digital oilers with the interval and duration timers? Somebody stop me indecision
Thread: Uncertainty of Measurement [Global Warming]
07/07/2021 10:51:16
Remember, this is attribution, so there doesn't have to be any warming to make the temperature rise.
All you need is a fall during the calibration period, in this case 1850-1900.
07/07/2021 10:32:34
Attribution science graphs.
"Attribution science" meaning any climate variation that the maker of the graph could not explain must be due to carbon dioxide and human activity.
A novel approach to science that will probably last at least 20 seconds beyond the point where the funding runs out smiley
Thread: Milling arbor sans keyway?
03/07/2021 12:53:26
Posted by Journeyman on 03/07/2021 12:07:27:
A paragraph from my website regarding ISO etc. tapers
Tell me about it frown
I have a couple of ISO30 ER32 collet chucks that I bought before I realised Warco had it wrong.
I will probably give them to my son, he can flog them on that auction site and make a few quid.
There are some tasty, low overhang, INT30 ER32 chucks out there. I got one and am looking for another.
Robin
Edited By Robin on 03/07/2021 12:53:53
03/07/2021 11:58:32
Posted by Roderick Jenkins on 03/07/2021 11:33:40:
My Sharp mill has a 1" arbor without a keyway. I haven't had any problems cutting 20 DP gears.
I love it. I feel a deep need to cut gears, probably just a blood clot but it still has to happen thinking
03/07/2021 11:54:38
Posted by Howard Lewis on 03/07/2021 11:38:41:
The 22 mm arbor is probably intended to carry Slitting Saws
A Slitting Saw should never be used with a key.
Fascinating. You might think it would make more sense to omit the keyway from the saw rather than the arbor.
Could I be up against some weird H&S thing?
Robin
03/07/2021 11:45:49
Posted by Dave Halford on 03/07/2021 11:27:17:
The Warco ad claims ISO30, which was fitted on some late Centec 2B machines. Power output is similar as well.
The Centec does not require a keyway, the friction from the arbor nut is sufficient to prevent slip even on a 3/8 wide cutter.
The Warco Ad confused me. ISO30 lacks the driving dogs, whatever they are called, so this is INT30 which has them. There is also BT30 for auto tool changers but it isn't that either.
I think I have to cut the keyway to keep it cushty, but if I can get away without then I am safe to buy a set of involute cutters and see how big the keyway needs to be.
I have a 6mm broach so I am hoping it's a 6 smiley
03/07/2021 11:17:57
Posted by Andrew Johnston on 03/07/2021 11:11:35:
Are you sure it's INT50?
No it is INT30, I have a problem with my brain sad
03/07/2021 10:33:09
I bought a new Warco HV mill and I love it to bits, lots of bits, it is all in pieces but slowly coming back together.
It came with two horizontal spindles, 22mm and 27mm.
The 27mm has a keyway while the 22mm has none.
Is that normal? I have no experience.
I notice that gear cutter bores seem to depend on the Modulus. At M2.75 they make the leap from 22 to 27mm bore. I wondered if perhaps the smaller sizes need less torque? Seems unlikely.
Perhaps you are expected to cut your own choice of keyway. This could be catch 22 if all the milling cutters that might cut the keyway are bored 22 because they are considered pathetically small out there in the real world sad
RDG tools have a 1" INT50 spindle that would fit and lots of DP size cutters to go on it. Unfortunately, they forget to say if it has a keyway and I have become suspicious. Also, does INT50 imply it wants a 40mm support bushing at t'other end?
Too many questions thinking
Thread: Limp Probe
03/07/2021 08:50:55
The £60 one on eBay?
I was a bit puzzled by mine until I figured out I had to remove the blue plastic ring. It didn't want to come off, snapped in half when I insisted,
I haven't used it yet but it seems okay, maybe you got a dud.
Thread: What Cutter For Big Cuts On A Small Mill?
22/06/2021 19:06:33
I reach for one of my trusty 12mm Dormer TiCN Coated 3 Flute Rippers when things start to get tedious.
There are cheaper options which work just as well, but I got a deal on the Dormers face 22
Thread: Moving machines
22/06/2021 00:50:20
I realised that I don't actually need to lift machines very far to move them around my garage, an inch is overkill.
I took two lengths of 2" x 4" box section, fitted a heavy-duty castor to all four ends and adapted the machines so that the act of bolting them to the box sections lifts them 3/4" off the floor.
I still have jacks, engine hoist, 2.5-ton pallet truck, etc. but the box sections are my favorite..
Thread: Flintlock pistol plans
19/06/2021 12:16:14
If it was wheel locks then you would go for Bolek Maciaszczyk and his Facebook page Matchlock and Wheellock Guns. He was offering a course on making a wheel lock, maybe still does. He is very much into geometry, the workmanship is top notch.
17/06/2021 23:00:49
I have an unlicensed, antique blunderbuss collection. The police swarm over me occasionally but they have yet to cart me away...
Touch wood thinking
Thread: Etching Aluminium
13/06/2021 11:08:31
Posted by ChrisB on 13/06/2021 10:26:35:
it's one of the worst chemicals one can handle, so much so that apart from al the necessary ppe we also have a specific first aid kit with antidote for paramedics in case of an accident. Exposure effects of HF can be delayed, leading to severe injuries.
In the days before H&S schoolchildren were invited to etch glass at home using HF extracted from teeth secret
11/06/2021 16:50:09
Could you put an extra, caustic proof layer below the etch resist and develop that in a second tank?
Thread: DIY Hydraulic Press
11/06/2021 09:39:33
A hydraulic press sounds like a good idea to me but I am officially bonkers face 22
Thread: KENNIONS MODEL ENGINEERING SUPPLIES
08/06/2021 14:27:33
They sell precision ground EN1A round bar. Never seen it anywhere else.
Should they stop selling it, is there anywhere else?
Thread: Lathe run out
08/06/2021 10:32:33
I unscrewed the front. right foot until the DTI showed about a 0.0008" error.
I repeated the skim cut and measured it twice, using my new found skill for reading Vernier micrometers
Left-hand end 1.5696" or 1.5695"
Right-hand end 1.5698" and 1.5698" again
Will it stay that way?
26 thou on the screw moved it 1.3 thou on the diameter which is 20:1
