Member postings for Benjamin Carr
Here is a list of all the postings Benjamin Carr has made in our forums. Click on a thread name to jump to the thread.
Thread: Goodwin "Progress" Spindle Removal
27/07/2017 21:45:05
Evening all. I've spent today stripping down the gearset on my Goodwin model makers' lathe. I am now at the point of removing the spindle and front gearshaft. However, I am unsure how to proceed. From watching videos of spindle removals on other lathes I believe that it is usual to tap the spindle out from left to right, with the spindle coming out of the chuck end. But I can't be sure, since Goodwins are rare and information on how to rebuild them is even rarer! I thought I would pick the brains of more knowledgeable folk, since although I am mechanically competent, I'd really like to be sure what I'm doing before I start hitting a 100-year-old lathe with a rubber mallet. Photos of the front shaft and spindle, along with the bronze taper bearings, can be found in my album "Goodwin "Progress" Stripdown And Rebuild". Any help appreciated. Thanks.
Thread: Good Evening from Barnsley
26/07/2017 23:43:25
Keith, you, Sir, are a legend! I've looked and my lathe is almost certainly a Goodwin "Progress". Apparently the headstocks were of very strong construction and there aren't many of this lathe still around. I had noticed the gap bed and thought it unusual on a small lathe. Any idea where I would go to get more information? The mighty Google is flummoxed by it...
26/07/2017 23:17:09
Thanks for that Bill. Seems I've finally cracked uploading photos. Looking forward to getting it going, whatever it is!
26/07/2017 22:59:08
I've created an album. The photos are in there. If someone could let me know if they can actually see them that would be great.
26/07/2017 22:41:59
I'll have a look Neil and try again. It's odd, the photos in my posts are showing clear as day on my computer. 'Tis black magic! And Mick, I'm planning on using the lathe to make robotics and radio-controlled car parts. And anything else that takes my fancy!
26/07/2017 21:27:22
The closest thing to an identifying mark on the lathe is this number stamped into the end of the bed.
26/07/2017 21:25:33
This is a close up of the toolpost.
26/07/2017 21:24:12
The lathe has been partially restored. The gears need bushings and spacers as they currently run with a lot of slop, especially those on the rear shaft.
26/07/2017 21:21:02
There are four holes beneath the chuck where I assume the original nameplate would have gone.
26/07/2017 21:18:22
26/07/2017 21:12:26
Thanks for the welcome gents. I am currently trying to work out how to upload photos onto the forum. And Brian, mechatronics is basically a combination of mechanical, electronic and computer engineering. MECHA from mechanical, and TRONICS from electronics. As you may be able to tell, the computing aspect is my weakest point!
26/07/2017 19:29:41
Hi all, I'm Ben. Studying mechatronics at Uni, just bought a small lathe to make parts on. Trained in machine shop engineering at college five years ago. No idea what make the lathe is, as it has no identifying marks or plates, but it appears very old and very well made.
