Member postings for David Beacham
Here is a list of all the postings David Beacham has made in our forums. Click on a thread name to jump to the thread.
Thread: Hand saw with depth stop?
28/07/2017 09:10:50
Wow many thanks guys (wot no ladies?) there are some good suggestions there. This one is now out (not mine) apparently it was the carefull saw method. I will try the dowel to prevent crushing next time and look for those plastic clips or bend steel round the blade. One I did recently was steel to steel and I ended up using caustic soda, even then it was so badly welded in I could not get the remainder out with a chisel and eventually got enough out to put a shorter post back in. Oh and paint it of course. Once again thanks for your help. smiley
24/07/2017 10:42:56
I sometimes get bikes in with seized/stuck seatposts, is there such a thing as a slotting hand saw with depth stop to avoid cutting into the seat tube or do I need to invent one?20229238_1567833876582239_7423887733280616344_n.jpg
