Here is a list of all the postings Ninev Zia has made in our forums. Click on a thread name to jump to the thread.
Thread: Request of Help With Stuart Model 800 |
08/07/2017 23:39:39 |
Hi Hugh, Sorry to be a bit dense, but when you mention 61 cat, is that a 1961 Stuart catalog? Is that because the 800 was discontinued earlier? |
07/07/2017 13:49:42 |
Wow. What a wealth of knowledge here. Thanks so much Ian, Jason and Maurice. And I will reach out directly to Stuart. |
06/07/2017 21:34:02 |
Oh, thanks for that carb thread Jason! And thanks Jason and Neil for the welcome. : ) |
06/07/2017 19:45:43 |
As bad luck would have it, the (only) part that was damaged in shipping the engine to me was the carb - broken into three pieces. Assuming tbere are no longer any spare or replica parts for these, I will have it bonded then welded back together. |
06/07/2017 19:41:05 |
Thanks so much for the quick replies. I thought I had the hang of embedding pictures from my album to this thread, but apparently I need to go back and read the FAQ area. ![]() |
06/07/2017 18:33:39 |
Hello, I'm a long-time reader but first time poster. After a long wait, I am finally the happy owner of a Stuart Model 800 I/C engine. There are several things I am curious about in the case of my particular engine. -First, the configuration of the ignition system is different to what I have see on all of the other 800's I have found on YouTube and other sources. Does the system on mine in the photos below look like one of the options available from Stuart or could it be a separately sourced solution? - Also, mine has a cast aluminum carburetor on it, whereas in all other 800 engines I have seen, this carburetor is not used. - And third and lastly, I have not been able to determine when Stuart ceased producing these model 800 S. If anyone has inside to that I would be most appreciative as well. Thanks for any help! Ninev |
