Here is a list of all the postings Mark Beech has made in our forums. Click on a thread name to jump to the thread.
Thread: Single phase milling machine recommendations |
26/06/2022 10:16:36 |
I have a 3 phase motor with electronic variable frequency inverter on the lathe for many reasons wouldn't have it any other way, but I put a 1.5hp single phase induction motor on my Adcock and Shipley 1es and it does everything I ask just fine. I think its just capacitor start, some are cap start and cap run making them a kind of 2 phase motor, its been 100% reliable, no noticeable vibration and electrical usage - i don't use it enough to worry about. |
Thread: Stalling Lathe |
25/02/2017 13:29:02 |
I've browsed this forum for a while but this made me have to sign up. Many years ago whilst a young apprentice (electrical) i was walking past the machine shop and saw one of the fitters at the myford, i went over for a chat as one does. As I approached he said scratching his head" ok Mark, tell me what i am doing wrong". He switched on the lathe which spun up but as he tried to put on a cut the spindle stopped, you could still hear the motor running. "Here" i said with a smirk and engaged the drive peg (the one to allows the back gear to drive ) , I think it was something on the lines of "bugger off you clever little shite" with a red face. Hope yours isn't the same problem, ok its an easy fix but the embarrassment makes a motor rewind preferable. Also ours had myfords excuse for a clutch, he would turn the spindle disengaged but then slip with a light load. You should be able to open guards and see what pulleys are running and whats not and whether the motor is stalling.
