Here is a list of all the postings Alastair Spencer has made in our forums. Click on a thread name to jump to the thread.
Thread: Cheap chucks from ebay. |
15/02/2017 17:28:09 |
Thanks for all the replies. A lot to think about! It has a D1 3 mount. I found the broken tooth problem because the chuck was stuck about halfway open, so I dismantled it to see why. I haven't used a lathe much since I was at school so I'll need to start practising again. It is a three phase dual voltage machine so I have wired the motor for delta and am running it from an Invertek drive which I am pretty impressed with. I have mounted a 5K ohm pot under the direction change switch to control the variable speed facility of the drive which could be quite handy. |
14/02/2017 20:11:19 |
I've just bought an ex-school Boxford STS 10 20. It's in pretty good shape apart from the Pratt Burnerd 125mm chuck has a missing tooth on jaw number 3. The scroll looks ok. When you compare the cost and availability of replacement jaws, prices are pretty high as is the cost of a new Pratt Burnerd chuck. There are however a selection of Chinese chucks on ebay which are quite cheap. Has anyone got any experience of these cheap chucks? The prices are tempting! |
