Member postings for Ian Flannery
Here is a list of all the postings Ian Flannery has made in our forums. Click on a thread name to jump to the thread.
Thread: Threading stainless 8mm on lathe 7x14
09/02/2017 19:48:39
I make and sell items made of 316 stainless it's tough to work with even drilling can go wrong if you don't get it right
09/02/2017 19:34:10
Cheers for the help my lathe is cj18a 7 x 14 I think for stainless a larger lathe with more grunt would help .I have thought about 4 jaw chuck I think I'll just stick to die as I have to drill centre holes and use live centres to thread the bar on the lathe as the bar flexes and I get a lighter cut at the end if I don't use the live centre. Draper die only costs about 3.50 and last while with cutting oil .I think I just enjoyed the challenge of trying to thread on the lathe which I can manage but takes too long
Edited By Ian Flannery on 09/02/2017 19:35:30
09/02/2017 18:42:24
I see your point but 8mm is all I am threading so think will just use lathe to chamfer and then the die for speed I did get a mt2 die holder for the lathe but my 3 jaw chuck won't hold bar tight enough
09/02/2017 18:07:03
Finally got to grips threading on my lathe but don't see any benefit as it's so quick and easy using a die .I am using a hss cutting tool and would it cut better with carbide tips .
