Here is a list of all the postings Richard Barrett 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: Waterborne varnish. |
15/01/2017 11:01:54 |
Ahhh! Didn't know that, thanks brilliant. It's simple terminology I don't understand. |
Thread: Newby asking question. |
15/01/2017 10:24:30 |
Gents. As I'm new to this what extras do I need with the Proton DB250 for making floats. I only need to smooth down small piece of balsa wood from square into shape, maybe 4'' length at the most. Bamboo barbecue canes form the stems. Do I need a chuck to hold them in? Sorry I've never done any kind of wood work, so really don't know what a chuck does. What comes fitted with the lathe and what will it do. I see there is a pointed metal spike on the right side end, so this will fit into the wood when tightened, understand that bit. Can I add a small sander disc on the other end for fine sanding. Again sorry I'm so green, it's WHY I joined the forum. Kind Wishes .Richard. |
15/01/2017 10:11:05 |
Gent's. For my floats I've been told a waterborne varnish is best. Can you buy just a small amount. Most I've seen are in 5 litres, that would last two lifetimes for me. Thanks. Richard. |
15/01/2017 10:08:17 |
Guys. The Proxon looks ideal for what I need. The other lathes from China look amazing too, but I'd be a bit worried about any guarantee if it didn't work when it arrived or broke after a few weeks. Does it say how long the DB250 is. I could fit it to a board of some kind, so it's stable, but movable. Good price too, not that expensive for a few floats. Big, bIg thanks. |
14/01/2017 16:22:58 |
Can you get those Grizzly lathe in the UK. I have a drill I don't use, that would be ideal as I could take the drill off when not in use. I don't see a price on it on the site either? Thanks all know you trying to be helpful. If you can think of a small one just pass on the site and I'll look. I'll look at the Axminster and Arc right now. Richard. |
14/01/2017 13:30:02 |
Michael thanks. Really I'm after something I can just order and buy, rather than spend time searching for items not still available. But I will try a search, so thanks. I see Stanley do a small lathe, and also Draper, but I want something small and light if possible, coffee table size. It will have to be put away after each session. Kind Wishes. Richard. |
14/01/2017 12:16:55 |
Hello I'm new to the forum and wood turning. Retired and a fisherman. I'm making a few fishing floats for fun, also for a winter hobby. Balsa, cane and cork only. A few folk I know that do the same use a Unimat 1 for the process. I'm looking at this for it's size and lightness. I only have a tiny space in the conservatory and the lathe will sit on top of a float box, and inside it when I pack up. Wood only balsa and cork cane. However I've seen some bad press on the lathe, so is there anything comparable that will sit on a coffee table while I little away. Thanks Richard.
