Here is a list of all the postings dave train has made in our forums. Click on a thread name to jump to the thread.
Thread: Looking to buy a Warco Mill |
30/04/2023 18:26:08 |
Posted by JasonB on 30/04/2023 18:24:30:
Really only you can answer the question of whether your old WM18 was big enough to do what you want and fit in the shed or not and then size the new machine larger or smaller as needed. The WM18 was in a bigger shed, I have moved since then |
30/04/2023 18:16:11 |
Starting to think I will have to set my sights lower, possibly a WM14 or 16 Just looking at the Warco website I think the WM14 will be too small so the WM16 is now looking favorite Edited By dave train on 30/04/2023 18:21:52 |
30/04/2023 10:39:40 |
Posted by JasonB on 30/04/2023 10:07:49:
Looking back I see you already have a WM18 so these other mills being suggested don't really offer any more capacity to what you already have? Could be time for a bigger shed or smaller cars. Long story but I had to sell the WM18 due to financial circumstances. |
30/04/2023 10:37:09 |
Posted by Michael Gilligan on 30/04/2023 10:08:16:
Posted by dave train on 30/04/2023 09:57:04:
Posted by Michael Gilligan on 30/04/2023 09:29:49:
In the hope that this 6’ x 6’ does not yet exist … May I suggest a big concrete slab Do things in the right order:
That is, of course, a very brief ‘project summary’ … the devil will be in the detail. MichaelG. Its on a concrete slab . So … take note of Jason’s comment, and proceed accordingly. MichaelG. Yes, I will need to Edited By dave train on 30/04/2023 10:40:00 |
30/04/2023 09:57:04 |
That is, of course, a very brief ‘project summary’ … the devil will be in the detail. MichaelG. Its on a concrete slab |
30/04/2023 09:56:27 |
Posted by JasonB on 30/04/2023 07:04:50:
Does you budget include for tooling? could easily be 1000-1500 though some can be built up over time. No |
30/04/2023 09:54:47 |
Posted by Ramon Wilson on 29/04/2023 19:26:16:
Current equivalent is VM32LV - R8 taper. Looks very similar to the Warco WM18 |
29/04/2023 15:05:45 |
Posted by Ramon Wilson on 29/04/2023 14:15:22:
Dave I am intending to put my Amadeal bench mounted mlll up for sale this year. It has had little use since purchase, is in fine condition and comes with a lot of kit. It's buyer collect only (Suffolk) but if you are interested send me a PM and I'll forward full details. Tug Which model is it |
29/04/2023 13:53:38 |
The WM18 is also an option |
29/04/2023 12:12:10 |
A 6x6ft shed |
29/04/2023 11:43:16 |
After something heavy duty to make car and motor bike parts. Not models My budget is up to about £3500. I could probably get a used Bridgeport but dont have the sapce. So any reccomodations Edited By dave train on 29/04/2023 11:43:41 |
Thread: phosphor bronze interference fit |
14/11/2017 17:16:44 |
Oh bugger
Edited By dave train on 14/11/2017 17:25:37 |
14/11/2017 17:06:45 |
Wrong forum Edited By dave train on 14/11/2017 17:25:06 |
14/11/2017 15:03:10 |
The springs are replaced The bush OD is 20mm and the ID is 16mm PS Thanks for the replies Edited By dave train on 14/11/2017 15:03:47 |
Thread: Sltting saw, what to buy |
29/04/2017 10:10:18 |
I spoke to Chronos re the 22mm arbour and they said they are finding it difficults to sourse one. So I either go for 1" or like Ian suggested buy a blank arbour and make my own 22mm one I dont suppose anyone had a drawing of one? |
29/04/2017 08:12:53 |
Ah right makes sence. Your link to Chronos for the 1" R8 arbour with CSK Fixing, however they dont seem to do the same with a 22mm arbour. Neither do ARC, and suggestion as to where else I may find this?
28/04/2017 23:40:03 |
Arc do 22mm R8 arbours but the biggest saw is 80mm. If I want to go to 4" as Jason suggested then I will need to go to 1" bore - **LINK** It it as important metric vs imperial? So which is the best type of arbout, the one above or this one - **LINK** The Chronos one the saw is near the end however the Arc one looks like the locking nut will give a tighter fit? Edited By dave train on 28/04/2017 23:41:15 |
28/04/2017 18:44:58 |
Thanks Just one more question, if I also buy a blade for steel what tooth count wound you advide |
28/04/2017 15:00:06 |
Thanks What thickness should I get and will 36 teeth be ok? Edited By dave train on 28/04/2017 15:00:33 |
28/04/2017 08:17:17 |
The mill is a Warco wm18, R8 Max 2.5"
