Member postings for Bramhp
Here is a list of all the postings Bramhp has made in our forums. Click on a thread name to jump to the thread.
Thread: Colchester master 1.5 levelling
18/04/2018 22:51:52
hi I’ve a mk1 master with later apron does anyone know how many levelling bolts should be in the base, found one nice big one accessed through cupboard/ tool locker should there be more?
Thanks Phill
Thread: what am I
21/03/2018 22:30:47
Hi Brian, yes adjusters are allowed. MOT testing guide section 5.3 mechanical brake components. Information section “It is acceptable to fit cable expanders to reduce maladjustment.” Although it doesn’t mention in the current guide I’m pretty sure that the older guide used to say “no more than one adjuster fitted per cable”
Thread: Axminster 2 day lathe course
08/01/2018 21:15:49
just wondering if anyone is on the course wed thurs this week?
Thread: Phase convertor problems
20/11/2017 22:51:19
Had exactly same problem, trans wave static, been working fine changed lathe and encountered same problem as yourself. Thought lathe... nope.. thought capacitors in converter and took back to transwave they checked it over and found nothing wrong.... bought slave motor and connected that up, this helped in that I could get it working but still wasn’t brilliant. Then moved wiring around as per ‘tractor man’ bingo cured all issues sweet as a nut, doesn’t really need slave motor but bought it wired it fitted it under bench so it’s staying. Anyway I would try this before anything else as it won’t cost anything apart from 10mins of your time.
