Here is a list of all the postings Matty Bush has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford S7 rebuild - a few questions! |
15/12/2016 08:22:55 |
I was quite chuffed with the price we agreed and even happier when i viewed the lathe,quite a result.I just need to decide what to do with the remaining pieces once its all built back up, i may sell to fund the mill i keep promising myself!
So its safe to assume that these collets are not manufactured anymore? is it worth the hassle to machine a few or should i sell the chuck and purchase something a bit more up to date? KR, Matty |
14/12/2016 22:07:55 |
Good evening All!
Recently purchased a second super 7 minus a few bits (leadscrew,most gears,saddle/apron) for the bargain price of £275 with the vision of replacing my old sight glass headstock with the more modern one. The bed is actually in much better condition than my current one so i have stripped the motorising assembly off so i can give it all some much needed love and eventually a repaint, i have left the headstock in place as i see no need to remove it unless anyone would advise otherwise for any reason? I assume that my screw cutting gearbox can just be taken from my old and bolted straight onto the bed with its leadscrew and carriers? while i have it stripped is there anything worth replacing to save mucking around at a later date? It also came with a Myford cut off slide and lever collet holder, I don't see the cut off slide being much use to me and after some research i am astonished at the price of the MA99E collets!....£20-30 a piece...why!?
KR, Matty Edited By Matty Bush on 14/12/2016 22:38:01 |
Thread: Cleaning up lathes |
22/11/2016 22:06:05 |
Muzzer,
I much prefer the idea of a scrubber pad over wire wool which i imagine will break apart and get everywhere, especially where you don't want it to be! I am not looking for a concours machine to stare at but it would be nice to have a machine with a bit more shine - I am sure that if you have a good looking machine you are more likely to give it a good clean after every session. Thank you for the advice!
KR, Matty |
Thread: Which Bridge Camera |
22/11/2016 21:59:22 |
Random hobby as it may be, your picture caught my attention due to the name on the drain..... I picked these up a few years ago at a well known local "antiques" shop for £8 .....being produced in Bitton and these still having Brunel calibration stickers (Bristol) I would imagine they are one and the same. KR, Matty Edited By Matty Bush on 22/11/2016 21:59:43 Edited By Matty Bush on 22/11/2016 22:00:06 |
22/11/2016 08:04:41 |
Is it wise to use something abrasive on the bed though? Do you use oil aswell? KR |
21/11/2016 22:16:28 |
Good evening all,
I see some pictures floating around on the forum of some immaculate looking lathes with all metalwork looking bright and shiny, I am aware a lot of this is good care but being the owner of a rather mature myford super 7 that has had many owners i would love to know if there are any tips in bringing the brown patina on the bed and slides back to a bright finish without damaging the lathe.
I understand some people use wire wool but there must be a more gentle method!?
KR, Matty |
Thread: Boring small holes |
04/10/2016 10:12:04 |
Thank you all for the advice,I will give it a try!
KR, Matty |
04/10/2016 09:04:33 |
Thank you for the ideas,there seems to be a few ways to complete this one. I may have a go on some scrap with the D bit and see what results i acheive-i assume if it tapered the bore it would be larger near the bottom? The end mill sounds like a good option too,Would it produce a clean cut/bore for the complete 34MM depth?I am not sure how long the working end of the bit is.
KR, Matty |
04/10/2016 08:36:16 |
Yes it will be done in the lathe,So i will be bolting the slot drill into the tool holder and setting at say 5 degrees? Thank you for the help so far! |
03/10/2016 22:32:39 |
Good evening all, Just playing around with my beginner project- a unit steam engine and would like some advice on boring for the cylinder. The instructions say that it should be drilled 19/64 and bored/flat bottom drilled before finishing 5/16 with a reamer- is there a small enough boring tool available to save me having to modify a drill with my awfull grinding skills?! im hoping the answer is completely obvious as my searches for small boring tools has come up empty!-piston size is .3125 any advice is massively appreciated and hello to you all! KR, Matty
