Member postings for sean logie
Here is a list of all the postings sean logie has made in our forums. Click on a thread name to jump to the thread.
Thread: Pratt Burnerd 6 inch 4 jaw independant lathe chuck
18/12/2016 22:09:37
Well I tried cutting a 8tpi and it doesn't marry in with the gauge . I bought the gauges off eBay , I check my purchase history and the description says BSW & metric . . I'll try a 7tpi tomorrow and see . I only have a cheap calliper set but they seem to be ok ,I've check them against a Brown & Sharp micrometer .
Sean
Edited By sean logie on 18/12/2016 22:14:42
18/12/2016 20:06:31
Thanks guys ,I'll pluck up the courage and do it in the 2 wks I'm off at Xmas . Been testing the run out at max distance betwwen tailstock and chuck . My gauge is telling me .05 mm over 45mm .
Sean
18/12/2016 15:23:11
Mark I've just checked and it is a BSW gauge. Would the flatness not be ware and tear . The gauge seems a tight fit . And the backplate won't fit in the chuck with the boss facing out ,so I'm not sure how I'm going to make the register .
Sean
18/12/2016 13:23:34
Mark,I've added a photo of the gauge on the thread . Not sure how I tell what angle the thread pitch is .
Sean
17/12/2016 20:36:47
I'm not sure,calipers are out in the shed and it's pissing down ,I've just downloaded a measuring app lol . Od of boss is 55mm or just over 2" ,thickness Id to od is about 10mm .
Sean
17/12/2016 20:14:05
I'll take another reading in the morning of the thread . The back plate does have a boss of about 10-12mm .
Sean
17/12/2016 19:45:35
I was thinking of getting a friend to do it . How would the part be held . Mark i think it's about 45 mm .
Sean
17/12/2016 19:32:53
I wonder if the back plate can be made to suit the 1 3/4 8 thread
Sean
17/12/2016 18:04:30
Hi the back plate arrived today and it doesn't fit it's too small. I'm going to add some photos a nd a rough sketch of my dimensions of the spindle and threads .
Sean
Thread: Newb question
16/12/2016 18:48:05
Thanks all
Sean
16/12/2016 17:12:45
Posted by Roger Provins 2 on 16/12/2016 16:40:40:
The only 18 tpi whitworth I can see on the chart is 5/16"
Have you a link for the chart your reading from .
Sean
16/12/2016 16:34:21
A bolt broke that's used for carriage lock and I'm trying to order one and I'm crap at identifying whitworth bolts and I would appreciate a lesson in identifying whitworth bolts.
The bolt measures .298" in diameter, it has a 18tpi thread ,what size is it please .
A frustrated
Sean 😎
13/12/2016 13:52:09
Cheers Mark and thank you for all your help. Which forum did the guy have the two fortis lathes . They seem to be quite rare .
Sean
13/12/2016 13:04:43
The two links you gave me .
Sean
13/12/2016 11:57:58
I've ordered the backplate from rdg ,in the middle of negotiations with the chuck .
Sean
13/12/2016 08:00:23
Mark would the 8" the guy on ebay is selling be too big .
Sean
12/12/2016 20:43:14
Thanks Mark ,very interesting, was the forum .
Sean
12/12/2016 19:04:03
Posted by Chris Evans 6 on 12/12/2016 18:52:34:
I have a 200mm Pratt/Burnerd 4 jaw and think very highly of it. I have the same make three jaw chucks in 160mm for the lathe plus 125 and 100 for fixtures etc. All are good.
I was looking at the 200 mm version ,I'm unsure if it will be to big or not . My lathe 3 jaw measures 6.2 " Lathe has a 12" swing .
Sean
Edited By sean logie on 12/12/2016 19:05:06
12/12/2016 19:01:07
I shouldn't need a back plate with this should I ? I know nothing about chucks . I bought a set of thread gauges and measured the spindle threads , the gauges tell me that the threads are 7G 1/8-1/4 .
http://www.ebay.co.uk/itm/302162526825?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
12/12/2016 18:30:14
Anyone have/use one of these . I'm looking at one just and was wondering what the quality will be like .
Sean
