Member postings for martin dust
Here is a list of all the postings martin dust has made in our forums. Click on a thread name to jump to the thread.
Thread: Unknown tool
17/01/2017 21:51:28
anybody seen one of these before
Thread: motor
05/12/2016 00:38:15
yes it is single phase.
should of explained more needs to be switchable
04/12/2016 22:32:12
any body got any info if this motor can be reversed
15349639_10210976139661044_3236043037764171995_n.jpg15232295_10210976140141056_6335159919376322793_n.jpg15337492_10210976139101030_7846783000400029579_n.jpg
Thread: gear for a thread dial
23/11/2016 09:59:30
Posted by Speedy Builder5 on 23/11/2016 09:57:29:
Martin, check out your inbox for a PM.
BobH
just about to look thanks bob
23/11/2016 09:58:55
Posted by JasonB on 23/11/2016 07:55:37:
If the gear does not have to be super accurate then why not just use the rotary table without plates to get your 32 divisions 11deg 15' is not too hard to do. You can also cut it on the skew like the one in the link rather than use a standard gear.
"So any 16 (or 32 etc) tooth gear that basically will mesh with the leadscrew should do the job"
Although the gear may mesh you also need the diameter to be about right eg a 16T that meshes will be a lot smaller than a 32T that also meshes and the small one will possibly have the casting clashing with the leadscrew.
that is exactly what i am going to do.
after spending a lump of money out for the lathe i think my balls will no longer be attached to be if i spent more money. sad
22/11/2016 23:24:02
thank you very much Hopper that the sort of answer i have been looking forlaugh.
where i got it from the have a load of myfords and some spares so will go there tomorrow to see what they have.
i have a mill and a rotary table but got to wait till christmas to make any gears.
as my daughter is buying me the plates for it, they will be here next week nut not allowed to use them.sad
Edited By martin dust on 22/11/2016 23:24:23
22/11/2016 21:12:56
yes
22/11/2016 19:27:28
i have just bought a boxford cud 4 1/2 x 18.
it came without a thread dial so looking to make my own.
but looking for a gear to run on the 8tpi lead screw or how to make the gear
