Here is a list of all the postings Tim Clough has made in our forums. Click on a thread name to jump to the thread.
Thread: Naerok manual |
12/02/2018 08:07:37 |
The Naerok lathe is actually the SSB 5MK model.Anyone know how old these Are? Still looking for a manual.Would pay for a photocopy if anyone out there has one. |
29/01/2018 16:36:44 |
Has anyone got a manual for a naerok ssb 4mk Lathe or know where I can get One? |
Thread: Clarke cl430 lathe problems |
14/07/2016 16:11:32 |
Just managed to have a look at the problem again.Drive pin sheared on clutch shaft.Thanks for all your comments and help. |
09/06/2016 17:59:28 |
Hi Michael, I will have another look and report back. |
09/06/2016 15:31:01 |
The clutch shaft also has a shear pin in it, but I cannot see what use it is, as appears to do nothing.I wonder if something is Missing? |
09/06/2016 15:16:49 |
Thanks for your comments.The clutch shaft number 15 on the parts diagram is just spinning and I think this should be driving the leadscrew.I have the assembly out of the lathe and want to remove the shaft that the clutch shaft goes in to.Do I need to remove the auto feed lever First? |
09/06/2016 13:54:34 |
Just bought a clarke cl430 lathe with the auto feed not working.The gears are turning but not the leadscrew.Seems to be somethino broken around the clutch shaft.Anyone had any experience with this Lathe? Thanks |
