Member postings for Juan de Dios Baile Garcia
Here is a list of all the postings Juan de Dios Baile Garcia has made in our forums. Click on a thread name to jump to the thread.
Thread: Two cylinders steam engine.
30/08/2016 11:19:47
Thanks for your comments.
Now I'm doing a gearbox 2 speed. I will publish progress
26/08/2016 11:23:01
Hi,
I put the wheels were temporary. As there was a proper I decided to make some.
I fabricated a bending sheet metal bender tires.
Now looks better:
In this video the construction process is as follows:
Video 8
greetings to all.
24/08/2016 17:29:52
Hi,
With this engine I decided to make another car.
I began by chassis and wheels that had adapted.
Also manufactures an alcohol burner.
With RC station I control the passage of steam.
Video 6
then put a servo to control the direction and also changed the ratio of the transmission and greatly improves speed (weighs 9.5kg.)
Video 7
Greetings.
25/04/2016 18:56:15
Hello,
This was the boiler that did to the engine:
Video 3
As I was not happy I decided to build this other double body:
Video 4
I connected the engine to the boiler and this was the result:
Video 5
Greetings
23/04/2016 10:19:54
Hello,
As gain experience with the tools and knowledge I decided to make another more powerful engine.
This is two cylinders. They have a diameter of 20mm
Also it built manually.
Video 1
Video 2
Greetings to all
Thread: Steam engine - homemade
23/04/2016 09:49:31
Hello,
When testing the car I noticed that the curves slowed and the driving wheels skid slightly. To fix I decided to make a differential.
I changed the tractor to the rear axle and the front direction.
I did the front axle swing arm to better fit the ground.
Now it works much better.
This video shows the construction of differential and tests:
Video 7
My tools are slim, I have only an electric drill and hand tools.
My knowledge of mechanics were almost nil but my enthusiasm to get to an engine was big
Thank you for your attention and best regards
22/04/2016 10:16:06
Thank you very much Michael. I think now how.
After making the car I wanted him steering the rear axle. Powered by a steel cable like the old remote control cars:
Video 3
As it has a single cylinder 12 mm. diameter lacked strength and increase the diameter to 14 mm.
This is the result:
Video 4
Video 5
Then another cable controlled the passage of steam. I also built wheels:
Video 6
I hope having published it right this time.
21/04/2016 20:46:10
I feel that the videos are not visible. I did not do well, I will try to fix it
21/04/2016 17:20:33
Hello,
I'm new in this forum.
I would show my work.
I started with this hobby four years ago and this was my first engine:
https://youtu.be/3ToSUAvUF34
Later I got to build this car:
https://youtu.be/Rf9X8KNWccE
Greetings.
