Member postings for David Evans 11
Here is a list of all the postings David Evans 11 has made in our forums. Click on a thread name to jump to the thread.
Thread: ML7 lathe
15/02/2016 16:22:51
Hello Nigel
Many thanks for your prompt response to my enquiry. I take your point about the chuck unscrewing, I was intending to use the reverse function to part off as I have read somewhere that it is safer and more efficient to do it that way.
I will take your advice and get hold of a copy of the manual. Can I definitely assume that my perceived problem is a fault with the switch or wiring and not the lathe or type of motor.
Thanks again for your help.
Dave.
15/02/2016 12:03:21
I have just acquired an ML7 lathe, it is in excellent condition and seems to work well. I am very much a beginner and I look forward to working on this machine. I note that although the control switch has a forward and reverse position the machine will only run in forward whichever position the switch is in. Do some of these machines not have a reverse gear. Dave.
