Member postings for Jonathan Milner
Here is a list of all the postings Jonathan Milner has made in our forums. Click on a thread name to jump to the thread.
Thread: Rufforth Metal Man
26/01/2021 10:21:28
Thanks Steve, yes that's the man . I owe you a pint .
Jonathan.
25/01/2021 11:06:05
Hello, has anyone got contact details for the indoor stall at Rufforth autojumble that sells short lengths of various grades of hex and round steel and ss etc. Thank you. Jonathan.
Thread: Arc welder cooling oil.
07/07/2018 22:08:51
All up and running again .I have about 5 litres of new transformer oil left over if it will help anyone out.
25/05/2018 20:15:56
Ed , mine has a cork gasket . I reckon any oil tank will need a gasket on metal mating surfaces. I will report back when I am sorted with the oil,probably in a couple of weeks.Prices seem to be anywhere between about £60 reclaimed, to £120 new.
24/05/2018 08:53:11
Thank you for the replies.Its proving to be a bit elusive and expensive to source ,but a local nut n bolt supplier can get me some reclaimed transformer oil,so will probably order from them. I will wait a week or so , just in case I find a better offer. Cheers.
22/05/2018 09:26:09
Good morning all. I am looking out for about 20 litres of oil suitable for a small,oil cooled arc welder.I am in N.Yorkshire. Thanks.
Thread: Removing bearing housing
07/02/2016 11:49:17
Try heating up in the oven, appox 200C ,like Colin suggests, and then slap it down firmly on the bread board,so the housing drops out.Good luck.Another way would be to drill a couple of small holes through the casing to the bearing housing and try punching or pressing out,but again using heat.Hope this helps
