Member postings for Kevin M
Here is a list of all the postings Kevin M has made in our forums. Click on a thread name to jump to the thread.
Thread: Running coal fired 5 steam engine on gas
29/05/2018 09:54:57
Thanks guys, very helpful answers! That's what I wanted to know.
Have a great day!
29/05/2018 09:20:31
Thanks all for your answers. I appreciate every one of your answers.
I got a lot of mixed answers about mostly general usage of gas. I think I wasn't clear enough, so I will clarify some stuff. Sorry about that!
I want to use a propane/butane powered portable gas stove
(such as this: https://www.ebay.com/itm/3500W-Portable-Gas-Stove-Butane-Propane-Burner-Fit-Outdoor-Camping-Hiking-Picnic/322769488346?epid=8011435743&hash=item4b268f89da:g:syAAAOSwqF9ZxIBX).
I would put it under the firebox to get some steam in the boiler for a steam test. ( I don't want to run it on the track on gas!). I don't own a house and garden and a coal fire is stricly forbidden on our balcony, so instead of driving to my local club track everytime I could maintain and test the loco on my balcony using a gas fire.
Now, my initial question was if this is a safe methode for a boiler that was made for coal firing. I was not asking about the general saftey of gas. I'm not familar with the temperatures of a propane/butane fire or hard coal and melting temperature of steel so my second question was if the propane/butane fire gets hotter than a hard coal fire? I really don't want to melt my firebox!
Thanks all.
28/05/2018 22:06:03
Posted by J Hancock on 28/05/2018 21:44:21:
Safe ?
You have to remember it is gas you are using here, if the flame goes out and the gas keeps going ..........
what happens next depends on how far away you are.
Thank you, but I was asking if its safe for the boiler and firebox.
28/05/2018 20:46:43
Hello,
that may be a stupid question, but is it safe to run a coal fired steel boiler on gas using a portable gas stove under the firebox? I was under the impression that gas gets hotter than hard coal, because it has a blue flame but that is not the case, is it?
Thank you!
Thread: What is this for a screw?
21/09/2016 18:50:24
Hello dear model engineer friends,
I recently bought an live steam engine and I'm a total beginner, so its would be very kind of you if you can help me on that one:
I want to replace some worn screws, but I really have a problem measuring them.
If I measure the outher diameter of the screw thread and compare it with BA (which I guess is the screws thread) it does fit into the BA11 category, however when I look at pictures on ebay of BA12 screws which is a number smaller, the threads are much bigger. So there is something I do wrong. I attached a picture of the screw.
I appreciate your help very much.
It shows 1.57 mm on the display, or 0.062 inches.
