Member postings for Kit White 1
Here is a list of all the postings Kit White 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Cross slide adjustment Myford ML7
01/05/2016 19:12:37
Sussed it. It was a combination of both the handle screw thread play and gib screws. I undid the lock nut on the topslide handle wheel, adjusted and and retightened it, then adjusted the gib grub screws. Thanks for the suggestions guys.
01/05/2016 13:41:56
How do you adjust the top slide on an ML7? Mine seems to lift up and down slightly, so simply adjusting the gib screws wouldn't eradicate this.
Thread: Turning a large diameter on my ML7
05/04/2016 18:50:09
Hi all, thanks for your input.
I can't weld to it as it is aluminium and I don't want to damage it.
I need to tap a hole in the centre anyway, so a bolt wouldn't be going out my way anyway.
04/04/2016 21:41:22
Here's my conundrum.: I have a piece of round 3.5" diameter (88.9mm) aluminum, and I want to turn it down by about .040" to 88mm. My chuck is too small to hold it, but I have 4 jaw that would, if it were longer than 20mm.
I need to drill a hole in the middle anyway, so is my best bet to drill the hole first, tap it for a bolt to hold it, then hold it the 4 jaw and use the dti to centralise it. Then, turn it on the bolt and turn down the diameter this way?
Hope this makes sense.
Thread: Best place for offcuts
08/03/2016 17:07:15
May try the local stockholders then, if I can verify the properties of it first.
Also, what is the approximate maximum size a 6" 4 jaw independent chuck will safely hold?
08/03/2016 16:42:48
As per title really, teaching myself to use a lathe and need a small number of approximately 6" max. lengths of diameters up to 3", just for practicing. What's the cheapest place to get this sort of thing? Anywhere sell offcuts just as general "offcuts"?
Thread: Threaded end mills on an ML7
10/01/2016 12:03:41
Posted by Andrew Johnston on 10/01/2016 11:52:37:
Posted by Kit White 1 on 10/01/2016 11:38:15:
I have a 1/2" end mill. They have threaded ends on them like this: Whats the best way without spending hundreds of pounds of holding them in my ML7 Myford lathe's spindle? Can I make a holder out of mt2 stock steel bar with a 1/2unf 20tpi thread on the other end which matches the end mills thread, and just fit that in the spindle?
Are you sure the thread is UNF? Threaded endmills are normally 20 tpi Whitworth, irrespective of whether the cutter is imperial or metric.
No, I'm not sure. It is 20tpi but probably is Whitworth in that case. Thanks.
10/01/2016 11:51:03
What type? Should it be mt2 or one that screws onto the spindles external thread?
10/01/2016 11:38:15
Thread: Keep snapping centre drills
29/12/2015 14:00:35
Posted by David Clark 1 on 29/12/2015 13:58:04:
Has it been properly restored or just given a rub over with wet and dry and a lick of paint?
Properly restored, pictures to prove.
29/12/2015 09:27:42
Thanks for the help guys, I have the handbook anyway.
28/12/2015 20:22:55
The tailstock can move sideways when not locked. There's a block underneath with two alen keys to adjust it against the lathe ways. Is this what needs adjusting?
28/12/2015 19:19:01
I wonder if any of you knowledgable folk can shine a light on my problem.
I am a newbie, having recently acquired a restored ML7 ,and want to teach myself how to use it. I have been reading books, watching youtube and practicing to try and find my way.
I want to drill a centre hole and using a centre/countersink drill in a Jacobs chuck, the moment it contacts the work it wobbles, describing an arc as though not straight. Keep advancing and the misalignment snaps the tool!! I feel the tailstock needs aligning. The locking lever can lock it in a different position if I slacken it, physically push the tailstock over, then lock it again, since there's play in the bed if not locked in position. Presumably this is normal?
I feel I am missing something embarassingly simple...
Thread: Tools for turning between centres
14/12/2015 17:17:10
Ok, glad I asked now. I guess times have changed since The Ameteurs Lathe from 1948, hence my confusion. Is it better to get a revolving centre like this or get a good used old one? How do these cheaper, newer ones compare?
12/12/2015 23:40:21
Thanks guys, turns out I had the correct undertanding first time round, I shouldn't doubt myself so much!! I am reading through the brilliant The Amateurs Lathe by L.H Sparey, but am just trying to put the meat on the bones, as it were.
My lathe already has the dead centre it came with, so its a carrier, faceplate and live/revolving centre I need.
12/12/2015 18:44:20
Hello all, I'm new to lathes and have recently purchased a Myford ml7, of which I am trying to slowly accumulate a basic set of the necessary tools I will need for hobby use. With regards to turning between centres, exactky what tools/accessories do I need? Two centres, one live, one dead (tailstock needs the dead centre, correct), carriers, faceplate etc?
On reading up on this, the work appears to turn against the dead centre as it stays still, but does this not ear the taper out quickly?
Thread: Myford Stand to floor mounting advice needed
06/12/2015 13:19:40
Much better!!
05/12/2015 22:02:51
OK, today I relocated the lathe and ditched the ply in favour of two lengths of 2x4" rectangular section steel. These bolt to the bottom of the lathe and then use rawl bolts through the floor as shown.
The lathe stand is much more stable on the floor, of course, but the lathe itself seems to rock on the stand still. The stand is not original Myford although is very convincing, but the feet which go between the lathe and the drip tray seem to flex the sheet metal on the drip tray top. I am hoping a flat steel plate to go under the drip tray on the roof of the inside (probably 3mm thick?) will cure this? Any suggestions?
22/11/2015 22:23:12
Thanks chaps,. Here's current setup..
22/11/2015 20:44:56
Hello all. I am new to lathes and need some advice on mounting my newly acquired ML7 Myford lathe stand (not original Myford but very convincing) to the workshop floor. The floor is flat but not level concrete. The lathe is on a stand, which has been put on a 12mm thick plywood board, but the stand has a slight wobble at the moment. I want to get rid of this, although the stand not being level isn't necessarily a concern by itself.
Is it best to a) shim the stand off the plywood until level or b), change the wood for a flat steel plate? I will sort out getting the lathe itself set level on the stand later on, once the wobble has been eradicated. As the wall behind is wooden, I may well also add some small angle iron to come from the stand/under the drip tray extending to the wall as extra support.
Any advice much appreciated!!
