Member postings for Mick Burmeister
Here is a list of all the postings Mick Burmeister has made in our forums. Click on a thread name to jump to the thread.
Thread: Beginners question (sorry) - why I am breaking my small centre drills?
23/05/2019 21:24:05
I've found some generic centre drills have overlong and fragile pilots. If you're cute with a bench grinder or patient with a hand stone you can reduce the length, as said above. When I tried paying a bit more for a good brand, I got shorter, more robust pilots that worked better. I still use the cheap ones as well, but don't put hard pressure on them in strong materials.
23/05/2019 21:24:04
Thread: Warco WM250V Oil Change
12/11/2015 22:49:36
Posted by mechman48 on 12/11/2015 21:47:21:
Mick B
IIRC... I have posted a couple of pics in the 'Warco 250 & WM 16 family' thread re. the hand wheel graduations in answer to another members question...
George.
Thanks George. I wasn't chasing tenths or working large lengths, so the 0,25mm ~ 10 thou approximation was good enough for work I've done in the 6 months I've had the machine; but I'll bear your results in mind for future jobs!
Compared to the Myford Speed 10 I had for the previous 15 years - the WM250V may not be as 'nice' in some respects, but it's given me substantially improved capability in many areas. Maybe I've been lucky, but bar stock in the 3-jaw runs true within 6 tenths. The vertical slide I bought with it is none too good (haven't really worked out what unit on earth the calibrations are supposed to be!), so I modded the Warco baseplate to fit the Myford double-swivel milling slide I already had, and that works very well.
MickB
12/11/2015 20:17:17
I phoned Warco with the same question, and their response was that the unit was effectively lubricated for life, and suggested I don't bother.
But I've another issue that I think will cause me to take the apron off, so I'll probably lose the oil doing that.
What happened was that I engaged longitudinal feed when I intended to use cross feed, driving the milling slide into the chuck-mounted endmill. It was one of the first cuts I engaged, so I didn't recognise the growl for a second or two. When I hit the emergency stop I couldn't at first disengage the feed or - obviously - move the saddle. I eventually succeeded, and found that the shearpin on the leadscrew hadn't broken, but the keyed sleeve in one of the changegear pairs had. Warco were very quick in sending a replacement.
But since that time I've been living with a stiff tight-spot on what I think is the rack to apron gear mesh, about every third turn of the carriage handwheel. My guess is that the crash bent the shaft a bit, but I won't find out till I drop the apron. Hopefully, releasing the telescopic leadscrew covers and removing the 4 vertical socket screws will let me do this. Anybody know?
I have found, by the way, that the saddle handwheel dial - although coarsely graduated in 0.25mm divisions - is actually pretty accurate, and you can judge it to a thou or two with reasonable confidence. I've milled slots for flush-fitting components with it with good success. The fine crossfeed is a delight, giving a silky finish on facing cuts and cross milling.
MickB
