Member postings for James Fitzsimons
Here is a list of all the postings James Fitzsimons has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford cross slide
15/10/2015 23:14:44
What a clever idea! I'd like to add one of these to my lathe too.
Phil, any chance I can trouble you for a copy as well?
Cheers,
James
Thread: Rotary table suggestions for Myford vertical slide
14/10/2015 10:59:05
Just wanted to say thanks to everyone that has replied to this thread. I'm going to change tack and go for the milling spindle approach as I think I will end up with a more useful tool.
Thread: Motive power for a toolpost spindle
14/10/2015 10:48:59
Thanks guys, I think I will try the 90w motor. It's really only going to get pretty light work anyway so I doubt it will ever be pushed beyond it's limits.
James
14/10/2015 07:38:46
Posted by Roderick Jenkins on 06/06/2014 22:12:15:
Just watch out for the power rating - standard motors are only 90W.
Hi Rod,
Apologies for resurecting a thread that's over a year old, but I curious as to the final warning about standard motors only being 90w. Will the 90w motor not be sufficient for a milling spindle?
My local supplier here in New Zealand only imports that model so will need to look for alternatives if that isn't going to be powerful enough.
James
13/10/2015 11:10:53
Humm, perhaps the milling spindle is a better approach. Definitely a more versatile tool at the end, and those sewing machine motors look pretty easy to come by for not too much money.
Building the spindle would be a good learning exercise as well.
13/10/2015 09:21:33
Thanks for the advice guys!
I felt the HV-4 wasn't going to work, so am glad to have it confirmed by people far more knowledgeable than myself.
I have been tempted by the 4" table on RDG (I've purchased from them several times and the service has always been outstanding), but the shipping to New Zealand on such a heavy item is just way too much.
I think I might try this one out https://www.machineryhouse.co.nz/R001. It's probably pretty budget quality, but for what I am hoping to achieve it will probably do fine.
MichaelG - I do have "Milling in the Lathe". Fantastic old book as you say, and I actually quite like the idea of the milling spindle for the vertical slide, but then you have to find some way to power it...
I don't want to over invest either as I definitely plan to get a mill at some point. It will help with the "significant other" if I produce some results and prove I'm serious about this hobby first though
James
13/10/2015 07:42:07
Hi all,
I am a novice model engineer and am just getting to know my Myford Super 7. I shortly want to embark on a small IC engine project that will require a rotary table for one or two parts.
As I don't have a mill yet I will be doing any milling required on the vertical slide of my lathe, so I'm looking for suggestions for the best rotary table that will work with a Myford vertical slide (I only have a very basic non-swivelling type).
I really like the look of the Vertex 4" HV-4 but am not sure it will be able to be mounted on the vertical slide.
Thanks for any and all advice you can provide!
James
