Member postings for Georgineer
Here is a list of all the postings Georgineer has made in our forums. Click on a thread name to jump to the thread.
Thread: Telephone Ringback Code?
11/06/2022 17:42:31
I used to have the ring-back code but last time I tried it, they had changed it.
One possibility nobody seems to have mentioned is to ask a friend or relation (or that nice chap from Amazon who's so concerned about unlawful activity on your account) to ring you back. If you have a mobile, you could also ring yourself from that.
Does anybody know if the old-fashioned pulse dialling, loop-disconnect, rotary dial type phones will still work?
George
Thread: What is "Mathematics"
30/05/2022 12:57:48
Posted by not done it yet on 29/05/2022 07:33:45:
The way I finally started working problems was to work out the units first, and if the units all cancelled out to give me the unit I was looking for, then I plugged in the numbers. I still use this method.
A useful tool for this (which I discovered disappointingly late in life) is the "Unity Bracket", which relies on the fact that any number multiplied by 'one' remains unchanged in value. So any conversion factor or complex unit can be rearranged to equal one and then cancelled down as appropriate, and if applied rigorously the answer can be guaranteed to be in the correct units.
If we want to convert miles-per-hour to feet-per-second we can approach it thus:
I don't know off the top of my head how many feet are in a mile, so I'll do that part of the conversion in two parts:
1 mile = 1760 yards, so by manipulating the equation we get
[1mi/1760 yd] = 1, and also [1760yd/1mi] = 1.
Also 1 yard = 3 feet, so [1yd/3ft] = 1 and [3ft/1yd] = 1
And 1 hr = 3600 sec, so [1h/3600s] = 1, and [3600s/1h] = 1
Those are our unity brackets.
To convert 40 mph to ft/sec we do it with unity brackets all through, selecting the 'way up' that will enable us to cancel out the units we don't want:
40 [mi/h] = 40 [mi/h] x [1760yd/1mi] x [3ft/1yd] x [1h/3600s]
Cancelling through:
which simplifies to (40 x 1760 x 3[ft]) /3600[sec] = 58.6 recurring [ft/sec]
As long as you know the necessary conversion factors you can then go on to convert it into metres/sec, furlongs/fortnight, parsecs/femtosecond and so on, in complete confidence that your answer will be correct (as long as you have doe your arithmetic correctly).
George
30/05/2022 12:16:54
It's interesting that - unless I have missed it - nobody seems to have mentioned arithmetic, which is concerned with numbers, while mathematics is concerned with anything but. It is the proud boast of many a mathematician that they can't do artihmetic.
If you look at the Greek roots of the word Geometry, it tells you that its origins lie in measuring the Earth.
And it took me until my sixties to discover that trigonometry has to do with the properties of the trigon. What's that? Count down from, say, octagon: heptagon, hexagon, pentagon, tetragon, trigon. It's a figure with three angles.... Oh! It's a triangle!
Now I must find out about algebra.
George
30/05/2022 12:04:33
Posted by Andrew Johnston on 29/05/2022 21:06:01:
[Maths] exists in its own right and is independent of any practical application, at least to pure mathematicians. Mathematics is a useful tool, but is not determined by physical applications.
That was the attitude of the lecturers visiting from the maths department when I was doing my Electrical Engineering degree. They hated us because we kept sullying their beautiful Maths with real-world applications, and even more so because we used j for the square root of -1, because,as far as we were concerned, i was already taken for current. However, I found their explanation of imaginary numbers very helpful:
First, imagine an xy graph with real-positive numbers on the right-hand of the x-axis.
If you then multiply the real-positive numbers by j you have imaginary-positive numbers. Treat j as a 90° anti-clockwise turning function, and any imaginary-positive number can be plotted on the upper half of the y-axis.
Multiply the imaginary-positive number by j (turning it through a further 90°, so you have multiplied the original number by j² = -1) and you have a real-negative number which lies on the left-hand side of the x-axis.
Complex numbers (with both real and imaginary parts) lie somewhere in the xy plane.
If my half-century-old memory serves, this is called an Argand diagram, after the French mathematician Robert Argand, who discovered (or invented) it. I am sure my old lecturers would be scandalised if they knew how useful it has been to me
George
Thread: Milk container top colours
27/05/2022 15:20:05
Posted by Samsaranda on 26/05/2022 17:41:47:
Just read on the internet that Waitrose are scrapping red and green lids on their milk containers because they can’t be recycled for food grade packaging, in future they will use clear plastic that can be recycled for food grade packaging, well we live and learn. Dave W
Our local Waitrose went over to the uncoloured caps for about two weeks, and now they are all coloured again... Figure that out!
I've noticed that the caps on plastic bottles are different in different parts of the country, so there is presumably no general regulation that applies to them.
George
Thread: Nostalgic moment
26/05/2022 11:02:31
...After it was all back together the Haynes manual arrived and apparently we should have taken the engine out rather than just undoing the mounts and pushing it forward.
It's not uncommon for manuals to suggest doing things the long way round. For example, to get the Morris Minor master cylinder out (according to the Morris workshop manual), one was supposed to drop the whole offside suspension to get enough clearance to withdraw the master cylinder fixing bolts from the chassis rail.
We used to undo enough of it to get access to the torsion rod with a crowbar, then gently lever the torsion rod until the bolt could be removed. When re-assembling, the bolt was entered from the other end with the nut behind the torsion rod. Problem solved!
There's something similar on my current car, where one is supposed (according to the Haynes manual) to remove the steering wheel and half the dash to replace bulbs behind it. 'Tain't necessary!
George
Thread: HOW FAST - ANEMOMETER CALIBRATION ?
25/05/2022 18:09:44
Posted by Nick Clarke 3 on 25/05/2022 08:36:59:
Just skimmed through 'The Amateur Scientist' and looked at the article on cloud chambers.
While it explained why i could never get a convincing demonstration of a cloud chamber in any of the physics Labs that I taught; the fact that Scientific American magazine would send out a 'speck of radioactive material' through the post on receipt of a stamped addressed envelope is thought provoking!
Edited By Nick Clarke 3 on 25/05/2022 08:37:27
If it's natural rock there are probably no regulations to meet.
When I taught Physics I was always amused by the fact that our 'official' sources had to be kept in lead-lined boxes in a locked dungeon and logged in and out, whereas the natural rocks, which were far more active, lived in a cardboard box in the prep room.
George
24/05/2022 13:06:19
I had a similar experience when my old Morris Minor Estate (LTP 809G) cropped up on Car SOS, as the working example they take out and interview the owner of. I made various attempts to make contact with the present owner, but wasn't successful. Perhaps I should try again.
George
Thread: Myford ML4 change gear modification
17/05/2022 10:35:38
Posted by Nick Clarke 3 on 17/05/2022 08:40:52:
... why might you ever need to remove a pin? ...
Three reasons spring to mind. First, for convenience in storing unused wheels. Second, to allow idler wheels to rotate freely. Third, it reduces the number of pins you need.
The Myford pins, though tiny, had beautifully domed ends.
George
16/05/2022 18:02:17
Posted by Nick Clarke 3 on 16/05/2022 07:44:59:
A reminder that the original Drummond/Myford pins were tapered and only fit from one side.
I would be tempted to not do this with your new pins but use parallel pins held in place with loctite or similar.
I can't answer for the Drummond (though I have my suspicions) but the Myford used parallel pins of 3/32" silver steel. I have this in original Myford paperwork somewhere. Not Loctite - you want to be able to remove the pins, so nothing tighter than a sliding fit. .
The Myford way was to drill blind holes in the gears and collars, which trapped the pins in place. If you drill through-holes, the pin will work its way out and let go in the middle of a cut. Don't ask me how I know.
Ajax, I have used the pin drive system on my father's and then my own ML4s for over fifty years and it never caused the least problem that wasn't of my own making (see above!).
George
Thread: Myford ML4 cross slide
14/05/2022 17:10:00
Backlash in itself is not harmful, and it should be routine practice always to make settings and apply feed from the same direction to eliminate it.
If the cross-slide feedscrew is only worn on some threads the feed-per-turn will vary slightly from turn to turn, so you won't get exactly 83⅓ thou for each turn. How often and how much would that matter?
Father compromised on his ML4 by putting packing between the cross-slide screw-plate and the cross-slide casting, to bring forward the less used portion of the thread. In all the years I used it I never noticed the difference, and for some years I used it to produce commercial parts.
George
Thread: Gallium
09/05/2022 20:36:16
Posted by Michael Gilligan on 08/05/2022 14:09:14:
Would I be right in assuming that only a few of the contributors to this thread have yet read the paper that was linked in the article ?
Guilty as charged. Should I resign?
George
Thread: Weight of Myford ML4 ?
09/05/2022 20:33:00
Ajax, that looks convincing for an ML4. Does your weight of 50.1 kg include the drip tray shown in the photos? I have recently lifted an ML4 (less tailstock and drip tray) from ground level to car-boot level without distress, so I would estimate it about 40 - 45kg plus those bits. Unfortunately my ML4 leaflets don't give weights, so I can't quote from source.
And before anybody asks, yes I have the manual handling and lifting certificate (and a 35-year-old disc injury) so I don't take chances!
George
Thread: Gallium
07/05/2022 22:30:31
Posted by V8Eng on 07/05/2022 17:49:58:
Posted by JA on 07/05/2022 17:43:48:
Was not Gallium used for doping Germanium in early semiconductors?
Far to busy, or lazy, to look at Wikapedia.
JA
I recall something called Gallium Arsenide in respect of that..
Without looking it up, I think GaAs is/was used in red LEDs. I know Gallium Arsenide Phosphide (GaAsP) was.
George
Thread: Ambiguous words
30/04/2022 01:15:29
Then there's bolt, as in "making a bolt for the door".
George
26/04/2022 10:56:53
Posted by Bazyle on 24/04/2022 13:44:05:
Kind of in the opposite direction I remember listening to Voice of America news read in 'Special English' - a vocabulary of just 200 words but sufficient for the task.
I once had a copy of 'The Bible in Basic English' which restricted itself to a vocabulary of a few hundred words, supposedly to make it easier for non-English speakers to understand. Unfortunately the translator had not simplified the grammar and sentence structure at all, so it was, in my opinion, as diffcult to read and comprehend as the King James version.
While on the subject of ambiguous words, the word inflammable is a rare example of a word which has largely been retired and replaced by clearer alternatives.
George
Thread: Seeking advice on mains equipment earthing
25/04/2022 21:40:19
Posted by John Doe 2 on 22/04/2022 10:10:47:
Something I was taught many years ago is to make the earth wire longer than the 'live' wire inside a plug or a machine connection.
So in a 13A plug I make the 'live' wire just long enough to reach the live terminal but I make the earth wire longer than it needs to be with a loop or a fold so if the whole lead got pulled, it would tear out the 'live', leaving the earth wire still connected. Or if the lead was completely ripped out, the earth would be the last conductor to be disconnected.
This sort of follows on from properly designed mains plugs in which the earth conductor is the first to make contact when plugging in and the last to disconnect when unplugging - owing to the earth pin being longer than the other pins.
Edited By John Doe 2 on 22/04/2022 10:17:18
Something I've been doing since Dad taught me how to wire a plug in nineteen-sixty-... er... is that the time?
I did the same inside the film editor, for the same reasons.
George
20/04/2022 15:34:46
Posted by Swarf, Mostly! on 20/04/2022 13:22:01:...
Obviously you have changed the cable to upgrade from two cores to three but did that allow the previous cable clamp to be reused?
Yes, I'm pleased to say that it did. The three-core flex was chosen to be the same diameter as the original two-core, so I was able to re-use the original anchoring arrangements.
George
20/04/2022 13:08:33
I'm pleased to report back that the restoration has been successful. What took the time was getting my hands on a suitable bulb for a reasonable price. The previous owner had fitted a 12 volt car indicator bulb, which got a bit over-excited on 24 volts.
I concluded that there is no need to fit a fuse in the editor itself. I take John Doe's point that officially the fuse in the plug is there to protect the flexible cable not the equipment itself, but with a 3 amp fuse fitted in the plug it will blow long before anything else comes to any harm.
A 20-amp class 1 PAT test shows 0.03 ohm resistance (± tolerance) between metal casework and earth pin which is good, and insulation resistance between transformer windings >20 megohms, which is even gooder. My work here is done!
Thanks again to all who have contributed,
George
Thread: Interesting demonstration of hydraulic pressure
17/04/2022 18:03:18
Sitting in my easy chair yesterday I heard a clatter in the kitchen. I went to see what had fallen off the drying rack, and instead found a tidal wave of oil advancing across the worktop towards me.
We buy olive oil in large cans and I decant it into a square glass bottle. Last time I did this, I overfilled the bottle and screwed the lid on leaving no ullage, then put it back in its accustomed place next to the combination microwave oven.
My wife was using the conventional oven setting to cook a simnel cake for Easter (yes, I'm a lucky blighter) and the side of the oven got hotter than it usually does though still not above hand-hot. The expansion due to the heat was enough to burst the bottle, and by golly, did it burst!
Naturally the oil had spread quickly and soaked into everything it could reach. So I had the joy of cleaning up a litre of olive oil laced with glass, from big shards to tiny splinters.
I shan't make that mistake again.
George
