Here is a list of all the postings mark Tat has made in our forums. Click on a thread name to jump to the thread.
Thread: Boxford AUD head refurbish |
14/02/2021 12:02:47 |
HI,
I remember meeting some guys at one of the Model shows , offering a lath service. My Boxford AUD needs a new set of roller bearings fitted. Any contacts welcome
Kind Regards Mark |
Thread: New member interested in conner 222 |
02/01/2021 11:31:09 |
Hi. I am interested in building a conner 222.
Have been working on it for many years. See also my cnc site https://marktaft3.wixsite.com/siegx3cnc Kind Regards
Mark T |
Thread: Sieg X3 Mill Super - Simple CNC conversion |
31/10/2016 10:41:38 |
Hi, I decided on using the Leadshine solution as I was worried about losing steps. This is another reason why i used toothed belts to ramp up the motor torque. They self correct trying to pull back to the known position. I have not got any other stepper motors to compare noise ratios, but is pretty insignificant when you start milling any way. I have found that the PC selection makes some difference. My original was an older scrap dell with xp and had to be replaced. My existing system , still hesitates occasionally , but is generally ok. At some point I may buy a more powerful 64 bit pc but its not really necessary. Try having a look at the pre-made aluminum mounting brackets, they can save a huge amount of time mounting the bearings.
Best wishes Mark |
Thread: An Alternative Regulator |
27/10/2016 09:12:12 |
I really like the Alternative regulator published by Roger Vane in Model engineer Jan 2016. If anyone is in contact with Roger , perhaps they could ask for any updates. Has anyone worked out how to stop the sticking? |
27/10/2016 09:02:00 |
Have you seen my Sieg X3 Mill CNC conversion. Enjoy.
Sieg X3 Super - Simple CNC conversion. Using mainly commercially available parts and a few very simple fabrications http://marktaft3.wixsite.com/siegx3cnc |
