Here is a list of all the postings Simon Head 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: EN24 Heat Treatment |
15/07/2015 16:11:35 |
Thanks for the information about the steels. How does this sound: I will check for marine U-bolts again, I have already checked but it is to go around the seat stays of my mountain bike to fit some stabilisers, they need to be a particular size to replace the ones that broke before I applied hardly any torque. The original set were very weak. The U-bolts are 6mm diameter. I was going to use EN24 or EN26 and get them Parco-luberized so they are coated black, they will be rubber coated black over the contact section. I may try making them from EN24, with no heat treatment to minimise cost. I can see if I can tighten this up without it breaking, using off the shelf nyloc nuts, Or can I make this from EN24T. What is this like to bend? The U-bolts are about 35mm wide and 75mm high. |
14/07/2015 21:30:01 |
Hi Modellers, I am sorry to post on this excellent forum but it seemed to be the only useful one! I want to make some U shaped bolts for a bicycle project I am doing. I was originally advised to make them from S155 Stainless Steel, then I thought they might be strong enough in a high alloyed steel like EN24 or EN26, initially in the annealed condition for turning, rolling threads on, and bending, then heat treated to the Z specification. Do you think this should be cheaper than S155 too? Some of your model stuff is very impressive.
