Here is a list of all the postings Andy Tyrrell-Clark has made in our forums. Click on a thread name to jump to the thread.
Thread: Burnt Bridgeport power feed control board repair query |
20/04/2020 14:41:05 |
Hi Clive, Many thanks for your messages - I've sent you a couple of PM's
Just to be a little clearer - the current board has a 12 pin connector but the wiring only uses 11 of those pins - there is an unused pin between the power inputs to the board and the first of the harness wires going to the unit itself. It looks just like the wiring I've seen in pictures of Erskine Boards (pic below).
Many thanks Andy |
20/04/2020 13:37:34 |
Hello Keith,
Many thanks for your response and the schematic which I had seen in the Hardinge user manual but unfortunately it doesn't appear to match my board which has significantly more components on it (approx 30 more resistors than appear in the schematic).
If I can't find the correct schematic for this board, it might have to be a case of replacing the whole board with an Erskine unit where at least schematics are available for future issues - probably not a bad idea as this one has obviously had a hole burnt right through the board at some point in its past.
Many thanks again Andy Edited By Andy Tyrrell-Clark on 20/04/2020 13:43:01 |
20/04/2020 11:08:04 |
Hello
I am finally getting round to fixing an issue on the Bridgeport series 1 BR2J2 Mill I acquired a little while ago. I purchased it knowing that the power feed on the X axis din't work and had just used it manually.
I'm now trying to get the power feed working again and it looks to have fried the control board in the past - hence why it wasn't working. As you can see in the pictures an area near the connector block has had some issues and burnt (possibly from the micro switches both being on at some point). Looking at the back of the board this is clearly not the first time it's happened judging by how a few of the components are attached and the jumper wires used. Obviously I'll test the micro-switches and motor etc in the unit before powering it up again if I can fix it
It controls a 6F (B or C) drive with a 12 wire connector
The problem I have is trying to track down a schematic for this board to try and figure out what the components that have fried were. It is not the common Erskine board that I have seen and I have been unable to locate images or schematics online that would appear to match this particular board.
Does anybody on the forum happen to know the make of this board and by any chance have either a photo or schematic so I can replace the burnt out components.
Many Thanks Andy
Board front: Burnt area: Back of board: Rear of burnt area: Edited By Andy Tyrrell-Clark on 20/04/2020 11:09:31 Edited By Andy Tyrrell-Clark on 20/04/2020 11:11:18 |
Thread: Pillar Drill advice - Meddings Driltru or MB4 |
17/06/2015 15:05:28 |
Thanks for a very informative and insightful post John - you've given me plenty to think about. |
14/06/2015 22:15:29 |
Many thanks for all the replies guys. I'll keep my eyes out for one of the MB4's which seems more capable for the lower speeds. I'm also keeping my eyes out for a reasonable Bridgeport mill and am in the process of picking up a Myford Super 7 Lathe (I know they seem to divide opinion). Those combined with a multitude of hand tools should get me well underway.
I'm sure they'll be plenty more reading and questions as i get back into this but thanks for all your replies and thoughts. Regards Andy
12/06/2015 14:35:37 |
Hello, |
