Member postings for SillyOldDuffer
Here is a list of all the postings SillyOldDuffer has made in our forums. Click on a thread name to jump to the thread.
Thread: Magnetic base LED machine light - WARNING MAY BE UNSAFE
26/05/2016 17:22:11
Hi nodeng2000
I read the text just before you deleted it. And I had just the perfect riposte too! You're quite right though : this isn't the place to cause trouble. In a way it's a shame - what other people think is important and interesting to me, and I sometimes change my mind.
Cheers,
Thread: An Application to create dividing head tables
26/05/2016 16:51:15
Posted by Michael Gilligan on 24/05/2016 16:02:16:
For anyone with 'BASIC' nostalgia:
Here's how I did it on the Commodore 64, in 1993
DIVIDING.BAS
100 PRINT CHR$(147)
110 PRINT "RATIO = ";
120 INPUT RATIO
130 PRINT "DIVISIONS = ";
140 INPUT DIVN
150 HOLES%=0
160 HOLES%=HOLES%+1
170 MAX=RATIO*HOLES%
180 LOT=MAX/DIVN
190 IF LOT=INT(LOT) GOTO 210
200 GOTO 160
210 TURNS=RATIO/DIVN
220 T%=INT(TURNS)
230 PLUS=LOT-(T%*HOLES%)
240 PRINT CHR$(147)
250 PRINT RATIO;":1 ";DIVN;"DIV"
260 PRINT T%;"+";PLUS;"/";HOLES%
Not guaranteed that I translated the BASIC correctly but this is what the program looks like in Python3 which is a modern "batteries included" language available free for Windows, MAC and Linux.
#! /usr/bin/python3
ratio = int( input( "Ratio = " ) )
divn = int( input( "Divisions = "  ) )
holes = 0
while True :
holes += 1
maxi = ratio * holes
lot = maxi / divn
if lot == int( lot ):
    break
turns = ratio // divn
plus = int( lot - turns * holes )
print( ratio, " : 1", divn, " DIV" );
print( turns, "+", plus, "/", holes );
Edited By SillyOldDuffer on 26/05/2016 16:52:23
Edited By SillyOldDuffer on 26/05/2016 16:53:48
26/05/2016 16:33:10
Posted by Malcolm Parker-Lisberg on 26/05/2016 16:09:09:
It means the EU wants to grab the money from Customs Duty for an import from outside the EU. But UK customs allows £25 worth of goods without having to pay any duty, as it costs more to collect than is due. So how decide which way to vote on June 23rd as the EU would like to collect the money, no matter what it costs.
Malcolm
Don't forget that this cuts both ways. British manufacturers are disadvantaged whenever Europeans fail to pay duty on imports from outside the union.
Note also that British manufacturing will not be protected by the Union if we leave it. Instead European industry will be competing head-on with ours.
The risk is that British industry unfettered by European rules will get duffed up by German, French and Italian industry as soon as they also are unfettered by European rules.
I expect Neil will ban us now!
26/05/2016 16:00:40
I think it means that you are liable to pay Customs Duty on the goods. As duty is usually collected on delivery you're probably in the clear. Fingers crossed!
Thread: Draughting Pens
26/05/2016 15:29:42
Posted by Neil Wyatt on 26/05/2016 15:24:50:
Posted by SillyOldDuffer on 26/05/2016 14:46:06:
Posted by Neil Wyatt on 26/05/2016 14:05:28:
Posted by Andrew Johnston on 26/05/2016 11:44:59:
Posted by JasonB on 25/05/2016 07:24:31:
PS could you provide one dimension so an idea of size could be worked out, say flywheel diameter
Jason: Flywheel diameter measures as 7.5".
And if you want scale, I suspect those brown rectangles at the bottom will scale to just under 9" long and 3" high - allowing for mortar
Bit blurred but there's a scale in the lower right hand corner of the drawing. I think it says 1 1/2 inches to the foot which makes 7.5" mean the engine has a 5 foot flywheel.
And makes the bricks 8.5" long, looks like they left the mortar out
Hiatus maxime deflendus!
26/05/2016 14:46:06
Thread: ZIEHL•ABEGG Axial Fan
24/05/2016 19:17:34
Posted by Howard Lewis on 24/05/2016 16:54:00:
Glad that Geoff now has the wind up!
With regard to boiler, or any pressure vessel, failures, think on the force produced from, say, 80 psi on a larger area. Would you want to be on the receiving end of even four square inches powered by 80 psi?
Looks like 320 lbsF (145KgF) And that is a small proportion of the area of even a small boiler. Add steam, under pressure, with its temperature raised, to say 170C at 80 psi, from memory. Then comes the heat energy. The latent heat of vapourisation of one gramme of water at 100C is 536 calories, which will reappear as the steam condenses, PLUS the heat liberated in cooling from 170C to 100C, plus that of the water as it cools to body temperature (from 100 to 37C) and you would have a serious scald, liable to remove skin. (Sorry about the mixture of units, but you get the message?)
A former colleague lost a finger or two when a compressed air reservoir exploded, because of oil vapour entering it, at high temperature. (Not too different from what powers a diesel engine)
For what my advice is worth, treat all pressure vessels with care. The last thing that any of us want is someone being hurt, and our hobby being labelled as dangerous.
Many thanks for the analysis Howard. Your numbers and description of consequences convinces me. I hope no-one thinks that my suggestion that "the potential violence of model boiler explosions is overrated" is any reason to believe that small boilers are safe!
My comment was partly due to something overheard at the Bristol exhibition. A chap was telling a friend that a small traction engine happily steaming away was nothing but a bomb on wheels. That I doubt, at least compared with a actual bomb of the same size.
Consider what Wikipedia has to say about Nitroglycerin: "Detonation of nitroglycerin generates gases that would occupy more than 1,200 times the original volume at ordinary room temperature and pressure. The heat liberated raises the temperature to about 5,000 °C" And the same source gives the detonation velocity as 7700 m/s. That's a lot of energy released almost instantly.
So there you have it: conclusive proof that filling a steam boiler with Nitroglycerin is far more dangerous than filling it with water! I claim today's prize for stating the bleeding obvious...
Neil's link about full size boiler explosions is interesting as is this one too.
I've never heard of a serious accident involving a model steam boiler. That inspires confidence in their build quality, maintenance and responsible operation.
Cheers,
Cheers,
Thread: cant add more photo;s to album
24/05/2016 17:28:24
Ubuntu 16.04 & Firefox 46.0.1 just uploaded a jpg with no problems here.
The message you get after refresh is OK, it stops you accidentally resubmitting a completed form. ( Resending a form would be embarrassing if you happened to be paying a bill. )
The white screen bit is wrong though. As your screenshots uploaded I can only think there's something odd about your other jpegs. The website doesn't just copy pictures so it might be their fault - uploads get resized and the forum's software could be gagging on something.
You could try using 'convert' on the pictures to force regeneration of the file, for example from jpg to png and back again. From a terminal:
5 minutes later, bird successfully rescued from my daughter's vile cat.
PS : convert can resize photos as well.  Minimising before sending has solved 'big picture' problems for me in the past.
Edited By SillyOldDuffer on 24/05/2016 17:31:17
24/05/2016 13:33:36
Posted by JasonB on 24/05/2016 13:22:05:
I thought that the pully and belt would drive a shaft to bevel gears just above the governor as I can't see any other way it is driven
Ah ha! That makes sense, no problem driving a governor with a belt.
Even though I can't see any valve gear I think it reciprocates too.
24/05/2016 13:10:43
Posted by Neil Wyatt on 24/05/2016 12:06:47:
Posted by SillyOldDuffer on 24/05/2016 09:55:11:
It's a Hydrostatic Switch from a mine, not a horn. It's main purpose is to activate the mine after it's been laid.
Thanks Dave, I assumed what must be the soluble pad was a rubber buffer.
Pleased that I figured out the basic operation though!
I'm a sucker for buying old technical books and trying to work out exactly what some of the drawings mean. Sometimes it's like doing a cryptic crossword!
I'm having a bit of fun in this thread decoding Andrew Johnston's Vertical Steam Engine. It looks as if a pin driven by the piston runs without lubrication in a circular groove: surely that would have caused trouble! It also seems that the valve gear is meant to be driven by a belt, which is peculiar too. (Not that I know anything about the subject!)
I guess the drawing is intended to give a general idea of the Engine's layout and some of the detail is missing.
Another mystery is what the designer thought the advantage of such a configuration would be? I wonder if it was ever built and what it was used for? If the brickwork is to scale it would be about 6 foot high. (The plan says it's scaled 1 1/2" to the foot but we don't know how big the paper is.)
The quality of the drawing and colouring is excellent: it must of taken a lot of practice to get that proficient. No TV or Internet back then.
24/05/2016 09:55:11
Posted by Neil Wyatt on 23/05/2016 19:08:44:
Posted by Georgineer on 23/05/2016 14:49:34:
Here's an exercise drawn in ink on linen by my mother as an 18 year old tracer in HMS Vernon (Portsmouth) in 1936. I still have the pen and compasses she used.
What a fantastic keepsake!
Is it a trigger horn off of a sea mine?
Googled this a bit - mines used chemical triggers, so is it a torpedo fuse?
Edited By Neil Wyatt on 23/05/2016 19:15:38
This drawing reminded me of something I read somewhere, and the strange workings of my memory finally retrieved it this morning as being from Norman Friedman's "Naval Weapons of World War One".
This type of mine is anchored to the seabed by a kind of winch and cable arrangement that sets the operating depth. This could be as deep as 100m to catch submarines, but more usually would be just too deep to be set off by passing fishing boats. Mines do not float on the surface.
In storage the top of the switch is sealed with a soluble pad. The mine is safe until this pad has been slowly dissolved by seawater, by which time the mine layer should be well away. The outer top cap is pulled off just before the mine is dropped into the sea.
Once the pad has dissolved seawater can enter the innards of the switch to press on the diaphragm. At operating depth the piston is pushed sufficient against the spring to make an electrical connection between the two lower bolts. This brings a battery into the firing circuit and activates the mine. After that bumping a horn will set it off.
A secondary purpose of the switch is to make the mine less dangerous should it accidentally come adrift. Randomly drifting mines are dangerous to everyone. If the cable breaks the mine floats to the surface. With luck removing pressure from the piston will disconnect the battery, making the mine "safe". I say "with luck" because after several months in the water corrosion or sea-life might have jambed the mechanism.
Friedman reproduces a drawing on Page 361 of a complete British EC II mine that includes one of these devices. On the drawing it's labelled "Hyd Switch Mark III" .
The drawing in the book isn't as good as that traced by Georgineer's mum. Well done her!
Cheers
22/05/2016 19:46:07
Posted by Neil Wyatt on 21/05/2016 21:41:41:
Posted by SillyOldDuffer on 21/05/2016 19:41:29:
Posted by Neil Wyatt on 21/05/2016 18:59:07:
Posted by John Haine on 20/05/2016 13:22:57:
Liquid oxygen Neil?
NI3
Purple mushroom clouds!
See Stub's post half way down this page:
www.model-engineer.co.uk/forums/postings.asp?th=72705&p=3
Sounds like we went to the same school!
One of my teachers, who had good cause to be concerned about the foolishness of clever inexperienced boys, often gave carefully designed demonstrations that deliberately broke the rules. Adding a test tube of water to a beaker of concentrated sulphuric acid; pouring water on to a large lump of Potassium; the travelling properties of petrol vapour upwind of a candle; Hydrogen and Oxygen; NI3. About a quarter teaspoonful of the latter was tipped on top of a tin of beans. He then spent about 30 minutes telling us stories of boys who had maimed themselves with home-made explosives before tapping the tin with a stick. The purple mushroom cloud was fun, but the hole blown clean through the top of the tin can was a lesson learned.
On the downside, having seen what a chemical explosion can do, I now suspect that the potential violence of model boiler explosions is overrated. Don't get me wrong, I'm not saying they would be harmless! But the amount of energy and the burst pressure must be relatively low. Has anyone in the Model Engineering community ever calculated the energy involved, or - even better - deliberately steamed a small boiler to destruction and documented the results?
21/05/2016 19:41:29
Liquid oxygen Neil?
NI3
Thread: Deliberate mistakes
18/05/2016 19:25:31
Posted by mark costello 1 on 18/05/2016 17:25:32:
I thought the Aluminum thing was interesting, now We have Chromium! Simple Chrome over here.
Now you're pulling our legs! And Chrome bumpers were once as common as muck over here.
You might like to spend a penny before we unleash the dreaded Britishisms...
Edited By SillyOldDuffer on 18/05/2016 19:26:23
Thread: Windows 10 forced upgrade
17/05/2016 13:34:03
Posted by duncan webster on 17/05/2016 11:51:32:Can someone explain why Microsoft are so dead set on me changing? My nasty suspicious nature thinks there is some plan to get money out of me in the future. At the very least I should have been given warning so that I could back up all my files.
Edited By duncan webster on 17/05/2016 11:52:16
Hi Duncan,
In the good old days Microsoft earned a very good living by selling software licenses. Not just for operating systems but also a wide range of development tools, Word Processors, Browsers, Spreadsheets, Databases, Games, and Web Servers etc. They also sell an excellent range of services in support of their software and how best it can be used by a business.
Microsoft's traditional income from licenses is drying up due to market changes. They lost the battle for Supercomputers and - much more seriously - that for the absolutely massive mobile market. Android is based on a Linux kernel.
Another way of making money from the web is to accurately target potential sources of income with advertising and other offers. Microsoft are interested in this market.
Accurate targeting is best achieved by tracking the activity of internet users. Their purchase history, contacts, and interests can all be recorded and analysed. There are many ways in which this information can be mined, for example to create and sell lists of potential customers to interested suppliers, or to identify market trends.
There are several examples of Microsoft moving into data collection and analysis. The Bing search engine collects usage data much as does Google. Windows 10 is free to customers but, unlike Windows 7, it "phones home" by default so that Microsoft can collect data about what you do with your computer. Most, but not all, of the "phone home" features can be turned off but the user has to realise first that this needs to be done and then has to wade through various settings to plug the leaks. These features are off by default in Windows 10 Professional but you pay a license fee for that.
Microsoft don't profit from people who stay on Windows 7 and there is new money to be made from Windows 10 and future upgrades.
I'm not bashing Microsoft. I benefit from two machines running Windows 10. I don't suggest that Microsoft are in any way wicked in all this, it is simply that my and Microsoft's best interests are not necessarily the same!
Not everyone is worried by privacy issues. I'm pleased, for example, that this forum carries advertising targeted at me even though I am thereby outed as a Model Engineer! But, after a career in big IT I am very aware of just how much can be deduced from a large data set and also that the deductions can be used for good or bad. The Inland Revenue detecting tax-dodging is good. Criminals selecting vulnerable old people to scam is not.
Cheers,
17/05/2016 10:42:20
English is a minefield for pedants. For decades even well educated Brits firmly believed in the correctness of "Standard English" and "Received Pronunciation". Today's view is that "Standard English" is just another dialect, no more or less valid than English as practised in Yorkshire, Scotland, Wales, Zummerset or Birmingum.
British readers looking for another example of ill-considered authority might enjoy Strunk and White. "The Elements of Style" is mandatory in many US educational establishments and students are marked down if they don't follow its directives. Although the book does contain much good advice, native speakers will easily detect "rules" that are surely only the prejudice and personal preference of the authors.
A friend went to school in the US. Aged 12 it was agreed that it was OK for her to stand facing the wall whilst the rest of the class swore allegiance to the flag, but her refusal to spell words like colour, theatre, and aluminium correctly was always punished.
On the subject of Aluminum, the spelling is consistent with Platinum and Tantalum. Does anyone know the origin of these variations?
Edit Fixed deliberate error.
Edited By SillyOldDuffer on 17/05/2016 10:45:13
16/05/2016 16:13:11
Posted by Bazyle on 16/05/2016 13:14:47:
Wow, Corporate IT blocked access to your link Mike so must be juicy.
The grammar problem that is getting to me at the moment is the below reference. The Indians at work read that it is technically correct but don't understand that it is not like the above reference and not good colloquial English.
I wonder how many of you get what I'm talking about above and think below is an adjective.
Edited By Bazyle on 16/05/2016 13:15:30
Hi Bazlye,
I guess it should be "the reference below"? Or are you referring to the difference between "Above/Below" and "Over/Under".
I wonder what 'The Times' 's opinion would be?
I like to be pragmatical about these things. I used to drive a peppery colleague bonkers by using "practically" for "almost". He never twigged I was doing it on purpose! (He was spot on about my misuse of semicolons though; a habit I've never broken.)
Cheers,
Thread: carbide/ceramic tool inserts
05/05/2016 14:10:06
Posted by Sam Longley 1 on 04/05/2016 07:14:04:
Posted by JasonB on 03/05/2016 18:53:36:
Sam, it really depends on what set you have got and from whom as to whether you are tied in with obscure inserts or industry standard ones.
Post a photo of the Warco set with a rule up against the tips and we could have a stab at what you have. Hopefully standard size/shape but some sets have a few weard inserts particularly the threading and parting tools if you have a set that includes these.
Probably best to start another thread - "Name my inserts" or something similar
J
Edited By JasonB on 03/05/2016 18:58:10
Thanks for the reply Jason but I was thinking of taking them to the Doncaster exhibition & actually comparing them physically with what is on offer & see if that gets a result.
If that does not work then I will take your advice
Sam, if your Warco set happens to be the same as mine this listing may save you some time.
Cheers,
Thread: What has happened to this die to cause this ?
02/05/2016 22:42:28
Posted by Brian John on 02/05/2016 07:54:25:
So the shaft of the die holder has to be bored out to accept the rod ? I don't think my lathe would manage that ; die holders are made of pretty tough material. It is a good idea though.
Hi Brian,
Yes my die holder already had a hole drilled through it. Mine looks just like yours from the side but it must be a different make. It isn't "made of pretty tough material" either: I didn't have any trouble tidying up the bore, possibly because the thing was cheap and cheerful!
I wouldn't go to the trouble of drilling out a solid shank especially when using a tube as suggested by Neil is such an easy alternative.
I've had mixed results when threading. I suspect my issues were due to a mix of cheap and/or blunt dies, awkward metals and inexperience. Although practice has made me much better at recognising when to back off, I still mess up more often than I like to admit. One good tip I learned on this forum is that slightly reducing the diameter of the rod being threaded helps considerably in awkward cases, as does using lots of cutting fluid.
It's worth double-checking the diameter of your rod too: I have various examples of "4mm" rod in my scrap-box that actually range in size from 3.85 to 4.1mm Chaos ensues whenever I try to cut an M4 thread on to the 4.1mm rod.
Cheers Dave
01/05/2016 16:26:44
Further to Brian's original question I created a similar disappointment on a mild steel rod by cutting under power with a cheap die this morning.
The problem was due to swarf blocking the cutter. I was able to cut a reasonable thread using the same set-up by turning the lathe chuck by hand with frequent reversals to remove chips and add more lubrication.
I wonder if Brian's problem might be due to a blunt die tearing rather than cutting compounded by scrapings choking the cutter?
