Member postings for Ern Marshall
Here is a list of all the postings Ern Marshall has made in our forums. Click on a thread name to jump to the thread.
Thread: Pansy 060 steam engine
23/03/2015 00:45:25
https://www.dropbox.com/s/qfhioyl8osnad6d/Understanding%20the%20Pansy%20final.pdf?dl=0
He is a link to the Booklet on the Pansy 060 that we produced. The introduction explains the purpose of it
Again it would be best to copy and paste the URL into your browser
23/03/2015 00:06:52
Reference my previous post you may have to copy and paste the link into your browser
23/03/2015 00:05:24
https://www.dropbox.com/s/s6n7gqdka15mqoh/DSCN2562.MOV?dl=0
The link above is the first run of our Pansy 060 runs like a dream.
Thanks fellas
22/03/2015 06:16:26
Thanks Andrew
We all are extremely grateful for the help we received for this forum. The booklet is just a way of helping newbies like us
Thread: Pansy Securing Nuts
17/02/2015 05:37:44
Yes it was the valve cover Neil......so we didn't have t go near it
16/02/2015 08:32:12
Thanks Andrew
It is good to get amongst it mate, but we have found many problems underneath. Of course I'll be annoying the members with a heap of more questions.
If you look at my album you see them Andrew
16/02/2015 06:34:28
Well fellas we got it done with NO breakages. Thanks to you all,
Inside the smoke box right at the bottom covered with a layer of soot and junk. After scratching around with found a small cover plate. This when lifted and remove gave us access to a hole and t the bottom of that hole we found a head of a screw, we unscrewed it an off came the top with no problems.
I will put up some photos to the albun of what we found
. No wonder it would not run. But in hindsight we all agreed that it would have happened (broken) sooner rather than later. The next job is to find replacement parts, and get them flown out to Vietnam.
Thanks again
15/02/2015 08:31:31
Thanks Neil.....I hope you blokes are not getting sick of my stupid questions. I can imagine what some of you are thinking. It's long learning curve for us
15/02/2015 05:29:52
I would just like to say thanks for every bodies feed back.With any sort of luck we will have the thing dismantled by tomorrow Monday
Thread: Ern Marshall
14/02/2015 14:23:39
I hope you blokes have a lot of patience, because I have loads of stupid questions to ask
14/02/2015 14:03:00
Can anybody help here
14/02/2015 09:31:45
A further explianation.....sorry for the trouble
Attempted to remove the firebox with boiler and smoke box complete as one assembly but failed?
We need to know how the smoke box is connected to the main cylinder housing? Front of train.
There are numerous nuts below but the ones in the four corners are slightly larger than the others
and there is one in the centre that may also be used for connecting the cylinder housing to the underside of the smoke box?
We have disconnected everything at the cab end of the train, or at the firebox end and it is free.
We have removed the stack to access the blower mounting and removed it from inside the smoke box.
We then removed the steam pipe connection to the cylinders from inside the smoke box but cannot remove the smoke box from the cylinder housing?
It would be appreciated if your forum contact can assist us.
We do not want to remove the said nuts unless we know what they are for?
14/02/2015 09:24:46
I have put some photos up under Ern Marshall in ALBUMS.
We are struggling to figure out how to remove the firebox....ANY suggestions will be appreciated
Thread: Pansy 060
14/02/2015 09:20:07
We have now got the stage where have to strip the engine. There seems to be a bent rod under the tank. We have gotten this far but are stuck. Any help in getting it off will be appreciated
14/02/2015 07:43:33
Could anyone please help me. I'm trying to find electronic plans for a Pansy 060 Engine
Does anyone know where I can download or buy these?
