Here is a list of all the postings geoff ryan 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Vertical Shear Lathe Tooling |
11/01/2015 11:02:35 |
Jon, have you tried your boring bar for making facing cuts? It seems to me that the boring bar cutter geometry would also work for facing cuts, or am I mistaken? |
09/01/2015 00:29:00 |
Hi Jon, Thanks for sharing your design of boring bar. I particularly like the simple ground profile enabling the cutting edge to be kept very sharp. I can see myself making something similar for the finishing cuts to cylinder bores. |
08/01/2015 19:46:18 |
Hi All, this is the first post of a long term browser. I'm a novice machinist with an inherited Cowells lathe and still on the lower slopes of a steep learning curve. I'm currently machining some 0 Morse centres from silver steel and was having some trouble getting a decent surface finish. I saw this thread and thought I'd give a vertical shear tool a go. The results were great and being sure of getting both surface finish and dimension right when I make a cut is a real confidence booster. So thanks to all and particularly the American guy who went to the trouble of making the videos. |
