Here is a list of all the postings Nick Hulme has made in our forums. Click on a thread name to jump to the thread.
Thread: Mach 3 DRO question |
22/06/2015 20:25:29 |
Posted by Les Jones 1 on 11/06/2014 09:29:42:
Hi Richard, It doesn't, Mach3 depends upon the stepper system being correctly set up and not losing steps, there is no feedback. You can use inputs and scales to display positional data in Mach3 DROs (not the active ones under progrm control) but the software will not reference the data in real time or use it for positional correction |
Thread: EMCO FB2 vertical Milling Machine |
29/04/2015 16:52:15 |
Emco FB-2 - http://static.webshopapp.com/shops/036767/files/015177803/emco-fb2-milling-head-attachment.jpg Remove the 4 top cover fasteners, remove the bolts on the inside which retain the motor and then drill the right holes to fit a flange mount alternative or even drill & tap a non flange mount front cover and bolt that on. The FB-2 is a 6 speed head, the earlier 4 speed milling heads (MM1?) appear to have the motor front/gearbox top as an integrated casting - http://www.lathes.co.uk/emcomiller/ I'm only referring to the FB-2.
- Nick |
29/04/2015 13:45:37 |
The FB-2 motor is bolted to the top cover of the gearbox, it's a small diameter motor frame for it's power output but that's all that's wierd about it, it's spindle has a standard nose for it's shaft size, I just machined my new motor's spindle nose to match in size and screwed the parts on. If you were to go with slightly less power than I did then frame size wouldn't be an issue and the motor could easily be replaced. After all, it's just a motor and "Where There's An Engineer There's A Way", conversely I suppose "Where There's No Engineer There's No Way" - Nick |
29/04/2015 10:30:41 |
I've fitted a 4 pole compact frame 0.55kW motor and 240V Omron inverter to my FB-2 head, https://www.dropbox.com/s/wpthacbocfp2xx3/PICT1546.JPG?dl=0 The standard motor shaft was a size smaller so I stripped the new motor and re-machined the shaft nose in the lathe. The flywheel, primary drive gear and gearbox oil lift screw all attach to the shaft via the internal thread in the motor shaft nose. The plastic gearbox oil lift screw shaft is easily broken if the motor isn't carefully lifted out vertically but it's also easily repaired with a section of speedo cable inner and epoxy if you do break it and once you repair it this way it's no longer sensitive to handling or alignment. Measure your proposed motor carefully, even the compact frame motor I used required a spacer ring to move the mill head 8mm further out from the column, I could have removed a couple of fins and slotted the fan cover but I fancied the additional 8mm throat.
- Nick Edited By Nick Hulme on 29/04/2015 10:31:38 Edited By Nick Hulme on 29/04/2015 10:32:32 Edited By Nick Hulme on 29/04/2015 10:32:50 |
Thread: electric motor for the quorn. |
28/12/2014 17:45:05 |
How cheap is cheaper? If you gave price, rough dimensions, power output and speed it would be a big help. I'm using a (new) 0.18 Kw 3 phase motor and (ebay) VFD (for my engraving cutter grinder) that cost me £110 in total, how cheap do you need the solution to be? |
Thread: Gauge Blocks |
28/12/2014 17:15:39 |
Posted by Andrew Johnston on 31/10/2014 10:05:57:
So why does Starrett recommend wiping the mating surfaces with a cloth impregnated with a light machine oil, wiping the excess oil off with a second cloth, and the wringing the blocks together? Andrew It ensures the surfaces are free of dirt, you could use water but it would promote corrosion, you could use a degreaser but that would remove any surface corrosion protection. The assumption that the presence of oil will affect dimensions is bunk, if the metal has close enough contact to "wring" it will do so, if something is preventing intimate contact it will not "wring" I spent an entire Summer Holiday calibrating micrometers to ISO 9002 for IMI Leeds |
Thread: How close does a thread pitch need to be? |
28/12/2014 17:02:44 |
The reverse should be possible. |
28/12/2014 17:01:47 |
If you are using changewheels to do the job you just need the N-ThreadP software and a 127 tooth gear. |
Thread: metric drawings imperial workshop |
28/12/2014 15:51:43 |
For CNC you don't need to convert, you just need a Metric POST! |
Thread: Machining Polyurathene |
28/12/2014 15:46:50 |
Massive cutting speeds, really, really Huge! I turn Polyurethane seals at room temperature and use cutting speeds in excess of 600 m/s for clean surfaces, the heat is removed with the material at these speeds and the stock does not significantly change dimensions, Regards, Nick |
