Here is a list of all the postings Andy Joyce 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: First Locomotive |
26/12/2021 13:52:23 |
Fizzy, the loco was this one. Unfortunately ISRS could not test the boiler due to the stuck regulator and where unwilling to free it and issue a pressure test certificate (for a fee) due to the current workshop workload. Still interested to know what certification is required to run on a club track. |
24/12/2021 15:35:28 |
Thanks Nigel. Am I correct that all is needed to get a boiler certificate is a pressure test followed by a steam test. Intent would be to join a club and run it on their track. |
24/12/2021 15:19:03 |
Considering a 3 1/2 inch loco from Station Road Steam. Unfortunately the engine comes with no paper work or pressure test. Is this a dud engine to buy for a first off project? |
Thread: Purchasing an unknown build |
24/01/2020 17:43:41 |
Thanks Bill
24/01/2020 16:57:07 |
New to the hobby so wish to buy a 3.5 gauge ready built locomotive but those I have seen on a well known site don't come with any paper work. Is this a fools purchase as it will be impossible to get the necessary certificates without knowing the materials used to construct the boiler. |
Thread: Tube Notching |
11/03/2019 18:15:08 |
Well a diamond drill did semi work but found with such a thin wall the drill just deforms the tube. So I find the best approach is to grind a V then clean up the shape with the drill.
First batch of tubes cut so at least some progress is being made.
07/03/2019 19:18:42 |
Thanks Jason
Diamond drill ordered!
Did try end milling last night but that just deformed the tube. |
06/03/2019 16:07:31 |
Thanks Jason. Diamond drill now purchased. Also tried end feed milling this afternoon but the tube just deforms without any support inside. |
05/03/2019 19:52:00 |
Jason, Do you think this tool would work? |
04/03/2019 19:13:11 |
Colin Your diamond core cutter could be an option, but they are not cheap are they. Note they don't say they are suitable for metal. More tempted to try a carbide burr. Will talk tomorrow to the guys in our workshop at work to see if they have any suggestions particularly with regard to the use of a 4 flute milling machine cutter. |
04/03/2019 19:07:20 |
Page three shows a metal construction
04/03/2019 19:06:12 |
This site shows the construction of a 1/3 scale build Link |
04/03/2019 19:02:51 |
Tim Aircraft is a 1/4 scale Zavage Bobber which has an open construction so you see all the fuselage construction from the instrument panel backwards to the tail Would guess a 100 of so joints have to be made so need a system that forms each joint quite quickly. Will post a link that shows the construction shortly. |
04/03/2019 18:13:28 |
Tried another technique this evening which was very simple and quick. Using a standard 6 inch bench grinder, I ground an simple arrow shape on the end of the tube with an tip angle of about 90 deg going back no more than a 1/4 of the diameter, then cleaned up the shape with a round file of similar diameter to the pipe.
Result was not perfect but it was very quick with little burring of the tube. |
04/03/2019 18:01:21 |
Trevor
Those tools are no use as they will produce right angle cuts. What is required is a lap joint as pictured. |
04/03/2019 09:28:57 |
Need to notch joint multiple lengths of thin wall stainless steel tube prior to silver soldering to form a fuselage. Have 6.35mm OD tube with a wall thickness of 0.2mm which is to be joined to 7mm tube. So how best can this be done? wondering if I could use a 7mm 4 flute milling cutter in a pillar drill with the 6.35mm OD tube supported in a larger diameter tube to hold it. Would this work?
Tried making a simple grinder as pictured but this did not work at all. Perhaps a different stone type would be better
