Member postings for Peter Hawksford
Here is a list of all the postings Peter Hawksford has made in our forums. Click on a thread name to jump to the thread.
Thread: Rob Roy Boiler
31/10/2014 19:39:02
Thank you Julian and Brian for your feed back. I have checked the water gauge openings and length before, all ok. Good point about bush might be to long into 1/4" water space. Difficult to correct.
Thread: Boxford 9" VSL/L lathe
29/10/2014 16:08:03
Thanks Les and Mark.
Your right Mark, it is a Smiths Tach. and is original equipment on the lathe. Good point about swarf, I'll have a look.
And I'll have alook at Yahoo Boxford group.
Peter
29/10/2014 16:00:01
Thanks for the reply.
Boiler is quite old now this has been a problem from the beginning. Perhaps bubbles is not a good way to describe this. More like small air slugs that don't move. Our local water is very soft. It's always a concern not knowing the true water level. I've been wondering about adding a water column to see if that helps.
Peter
Thread: LBSC - PV Baker loco.
29/10/2014 06:48:13
Hi Paul, I too have been trying to track down drawings for PV Baker, with the idea of selling what I have. I accquired a running chassis from an estate,. Very unlikely I will do anything more with it. Too many more interesting projects on the go.
Peter
29/10/2014 02:59:54
Looking for suggestions how to repair, or know where I can get electrical drawings of the tachometer system on my Boxford 9" variable speed lathe.
Problem is, tach reads max RPM all the time when lathe is running. Mechanical speed control works fine.
29/10/2014 02:36:48
3 1/2" ga Rob Roy
Any suggestions why I get a lot of bubbles in the water gauge when steaming?
Frequent blowing down the gauge only helps for a short time. Makes it difficult to know where water level is.
