Here is a list of all the postings Steve Butler 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Huron NU3 Milling m/c adaptor |
23/12/2016 23:35:35 |
Hopefully i have sent some photo's of the drilling / milling head that the adaptor fits between (INT 40 male one end and 8 tooth drive dog other end) hope this makes it clearer as previously thought i would possibly make one useing a drill chuck INT 40 drive turned down parellel and make a drive gear out of some EN8' ish material or what would be better Sorry again for not being clearer and thanks again for all your feedback Steve |
23/12/2016 13:02:24 |
Hi all and thanks for the feedback To Bikepete there is one on ebay item no eBay item number: 221963367303
The one i have to make one for is similar to this one showing the adaptor next to the head i don't now of the heads origin
I was thinking of getting a drill chuck arbor without the chuck and turning it down parallel l was then going to turn up a drive dog and mill the teeth or mill the gaps and fit key steel and then fit to chuck adaptor
SB
22/12/2016 16:43:54 |
Hi I have been asked if i could make an adaptor for a NU4 Huron milling m/c vertical drilling or milling head attachment with a 40 INT drive Has anybody got one or any information about one please Or what would be the best material to make one out of Ie. EN8 I have taken dimensions to make one but if i could lay my hands on one it would be better and easyier Thanks steve butler |
Thread: M.E. Beam Engine |
13/06/2016 16:27:11 |
Hi Jason thanks for your help and info top man sb, |
12/06/2016 18:27:46 |
Hi thanks for the replys do you know what year volumes 121 & 122 are jasonb thanks sb, |
11/06/2016 17:37:43 |
Hi all Is there or where is the me beam engine articals sb, |
Thread: Quartering query |
18/01/2016 20:38:31 |
Hi and thanks to everyone for replying to my query i thought i had missed some other obvious point Also thanks for enclosing photos to show other jigs Steve
17/01/2016 14:40:55 |
In the latest copy of ME the Barclay well tanks of the great war part 10 by Terence Holland my question is reguarding the quartering jig fig 38 I can see that one drive dog sits up against the vertical part on the left hand side of the jig as shown and is on the same center line as the axle center and also that on the right hand side of the the jig the drive dog sits on the top of the horizontal part i can see that. But my query is shouldnt the horizontal plane be on the same center line as the axle centeres and not as shown above it no dimension is shown for this hieght Or have i missed something ? |
Thread: useful info |
19/11/2015 13:28:02 |
Hi all I found this phamplet whilst looking throught my wife's grandads books and found it very usefull maybe it will be usefull to some of you out there Steve |
Thread: Potty:- Helping Dad Grasshopper Engine |
06/09/2015 10:20:07 |
Definatly second that Stew SB |
Thread: Potty overcrank engine |
24/08/2015 12:56:50 |
Hi thanks for the feedback i will add the extra in the crank Part 14 ? on my drawing there is a thread 20mm long on one end and 5mm long on the other 3mm looks a bit short? sorry Thanks again SB |
23/08/2015 18:24:21 |
Hi Stew Another dimensional query On starting to make the cylinder fabrication it shows a cylinder centerlines dimension of 66.3 mm on checking the crank dimensions and adding up your dimensions it adds up to cylinder center lines of 60.4 mm is this correct or am i missing something Thanks SB PS your lads and dads simple mill engine is a very nice little and i enjoyed making it and it runs superbly
01/06/2015 16:02:41 |
Hi Stew Can you tell me what is the overall length of part number 14 rod in issue 4414 vol 207 page 487 Thank you SB |
Thread: compressor query |
05/05/2015 17:07:23 |
Thanks for the feedback sb |
02/05/2015 16:17:10 |
Has anyone used a bambi bb24v compressor to run stationary engine,s like helping dads current and earlier models Or is it better to go for a cheaper noisy type and spend the savings on sound proofing This is my first post and would appreciate any advice sb
