Member postings for Ron Sargeant
Here is a list of all the postings Ron Sargeant has made in our forums. Click on a thread name to jump to the thread.
Thread: QCTP for Warco WM240 Lathe
18/08/2014 14:17:57
The Warco toolpost seems to be on permanent backorder, so I looked for an alternative. The closest I could get was the HBM 51mm QCTP from RDG, which was a bit of a gamble as I didn't have any detailed specs for it.
As it turns out, it only needs one small mod, the bore in the base is the right diameter to fit the cross slide stud but isn't deep enough. It needs to be deepened by about 3-4mm. The stud is also a bit short and might benefit from being longer but it seems to hold well enough. The 4-wayrotation lock pin will need to be removed as it's redundant - plus the removal of the screw that holds this in stops it fouling the chuck on close facing operations.
