Here is a list of all the postings Peter Harris 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: Water Tank for Wagons |
31/05/2019 08:45:11 |
I used a plastic storage box with a clip-on lid I drilled several large holes in the bottom of the tender to let any water out and mounted the box on some 10mm blocks for the same reason. I've had no problems at all, no leaks and it was cheaper than brass. There was also very little work involved in making the outlet and fitting it to the bottom of the box. It's at the club but I can take some photos tomorrow. Peter |
Thread: French model Engineers |
09/05/2019 11:27:27 |
Try https://www.i-services.com/membres/forum/forum.php?uid=68638 and click on 'Inscription' at the top right As a forum, it's pretty moribund but you might get the information you want.
Are you located in France? Peter |
Thread: Newbie in France Needs Help |
15/11/2018 18:02:25 |
How about this: Le Petit Chemin de Fer des Ribières (87)Peter (in the north of France) |
04/11/2018 10:22:22 |
I'm in the north of France, nearer to Brussels than to Paris. Postcode 59400. I'm a memebr of the club in Oignies: http://www.cmcf-oignies.com where there is a number of amateur metal-bashers. For materials, we usually manage to find someone in the club who knows someone who can get offcuts, etc. Otherwise, it's on-line to order things. We're only a hundred or so km from Calais so we take a day trip to Alexandra Palace every year. Peter |
Thread: Du Bousquet's |
12/02/2018 07:53:56 |
I can confirm that it is a refernce to the colour of the machine. The chocolat colour is said to have been inspired by the colour of the uniforms of the Rothschild family's domestic servants. Rothschild was a major investor in the "Chemin de Fer du Nord". |
Thread: workshop removal abroad |
05/12/2016 18:18:00 |
If you're anywhere near Lyon: www.sinnet.fr |
Thread: Black 5 blast pipe |
17/05/2016 13:15:54 |
The figure 42 seems to be 1 5/8 in millmieters. The rule of thumb I was given is that the blastpipe nozzle should be 1/7 the diameter of a cylinder. This rule totally transformed my machine; before it was gutless, difficult to steam and prone to enforced stops due to low pressure. Now it steams beautifully. Peter |
Thread: Universal Coupling |
02/02/2016 19:59:34 |
A cap head screw and an allen key with a ball end. A bit crude but very cheap |
Thread: Special rivet , |
15/06/2014 11:28:03 |
Polly/Bruce sell exactly what you want. Page 53 of their catalogue. They also sell reduced head 3mm screws. Before buying the rivet head bolts, I tried theading some rivets - a long winded waste of time,, I had such difficulty holding them while threading with a die. |
