Member postings for Brian Rice 1
Here is a list of all the postings Brian Rice 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Midget 5x7 BA ring spanners
25/02/2015 19:30:36
Is there not metric equivalent spanners that fit?
Thread: An efficient slot method
25/02/2015 19:23:23
Not all Chinese tooling is rubbish you will probably find that your so called branded cutters are made in China like most things these days.
Thread: Car Boot Find! Part Missing?
25/02/2015 19:11:55
It's definitely not part of the Stuart engine I can not see why you would have it connected to the exhaust steam pipe also if you look at the rest of the plant it's not age related. But what do I know wink
Thread: What did you do today (2015)
25/02/2015 08:47:18
Spent the last 3 days in Hospital having needles stuck in me and been stuck in all sorts of different machines ie MRI CT X-ray ,I'am slowly starting to glow green. I'm on a Nuro ward with no release date if I wasimad when I came in I will be by the time I get out teeth
Thread: Imperial Spanner and Socket advice for a metric person
14/02/2015 18:58:43
NeailPosted by Neil Wyatt on 14/02/2015 14:53:24:
or this:
mole wrench
Actually the link Vic gives explains it all very well, except that UNF/UNC screws are 60-degree (like metric) not 66.
If working on 1980s Fords don't be surprised if you need three different spanners to remove one part such as a thermostat housing. I honestly think some Ford cars of that era had American, Imperial and Metric sizes all mixed together...
I thought all you needed on a Ford was a Birmingham spanner and a chisel.
Neil smiley
Thread: Short arms long pockets
14/02/2015 08:40:42
Ketan I think you've got your areas mixed those phrases are all from the Midlands Not the great Yorkshire were the capital of England is York.
13/02/2015 18:09:52
There is more room than having tooling in ,besides if I'am not going to use the tailstock I get the heavy lifting gear in and take it of. wink 2
13/02/2015 11:45:37
I am with you on your post,the problem is I have very little room i am tucked away in the corner in a bedroom,i am always lookingfor tooling only to find them where I used them last.
Thread: Looking for Engineering Co that does odd jobs
13/02/2015 10:40:50
Hi Ken you must have some industrial estate near by with enginering shops knock on a few doors you will be surprised how helpful some can be,ie few years back I need a back plate with a none to standerd pich to the threads ,second door I knocked on works manager said go and see Bill if there is nothing set up on the machine he will do it in his launch break for a beer went back next day all done at the cost of a ten quid
13/02/2015 10:30:11
Posted by Ian S C on 13/02/2015 10:27:29:
Doubt if the PM would have time these dayssarcastic.
Ian S C
To busy closing his Swiss bank accounts
13/02/2015 10:27:47
Posted by Ian Phillips on 12/02/2015 21:04:22:
Leaving politics aside, why would you want to cover the tailstock barrel?
Ian P
Ian to stop crap getting in the lathe only a 14in bed so not a lot of room to leave tooling in there.
13/02/2015 10:21:18
You trying to say I'm untidy how very dare you smileydon't have time to tidy
Thread: Little beam
13/02/2015 09:13:44
image.jpgIt's coming on nicely now to to the fiddle bits where's my magnifier image.jpg
13/02/2015 09:04:25
I think you need to go speck savers Phil it's a lump of cast with quick release, the rest of the lathe is made from some sort of monkey metal.
12/02/2015 20:46:05
image.jpgimage.jpgcoming from Yorkshire that often how we are described so to live up to the reputation I never chuck owt away because you never know cap of WD40 can makes a great quill cover on a mini latheimage.jpg and it's free.
Thread: What is this
11/02/2015 11:06:03
10/02/2015 21:08:35
had this in my toolbox for years I think it came from the old Raleigh pushbike works in Nottingham. image.jpg
Thread: SPG Tools
05/02/2015 19:37:08
Posted by Bazyle on 05/02/2015 13:16:07:
but none of you put in link
And it seems to be in Hinkley which is somewhere north of Watford so I probably need a visa and some injections before visisting.devil
You would not get past boarder control until you can spell Hinckley correctly smiley
05/02/2015 09:01:57
Think hard that extra inch makes a big difference one more thing with the lathe make sure it's the 14 inch bed there are a lot of 12 inch about which look like a bargain, if you are going for a mini mill also make sure it is belt drive not gears(people have had a lot of trouble with the gear driven mill very noisy gears tend to brake)all so go for the R8 spindle there is always good second hand tooling at good prices on the net. I am not trying to steer you in any way but also have a look at ArkEuroTrade in Leicester sometimes have some good deals on hope this is help full.
05/02/2015 07:43:05
Make sure you are getting a lathe with a 4 inch chuck not all do
