Member postings for martin cropper
Here is a list of all the postings martin cropper has made in our forums. Click on a thread name to jump to the thread.
Thread: motor giving problems
26/07/2014 21:31:46
hi phil no its a other motor my lathe is the same one on the link you sent me on lathes
it the bottem blue one except mine has no longer on fast and loose
its been converted to pullys and the motor fixed at the back
it has forward and reverse on the apron travel
and tumbler reverse and cross slide drive
the old motor was 3/4 hp
and started it no probs but was from the 60,s i think and had a wobbler
hense the change i will try put some photos on
but same as the blue / green one at bottom of page
i start it in free mode if you like with nothing else engaged if that makes sense
i have tryed starting on another setting there are 3 same as other but pulley drive
starts ok with bigger fuse but blows smaller one
i think probably a brand new motor and switch
thanks again martin
Edited By martin cropper on 26/07/2014 21:32:32
26/07/2014 18:10:38
thanks phili understand it a bit better now
the plates not that visable so couldent see any ratings
so would it be better to replace with a 4 pole motor
as to give more torq when starting the lathe which is direct drive no clutch
but thanks again for your advice
thanks martin yes
Edited By martin cropper on 26/07/2014 18:11:10
26/07/2014 11:06:52
thanks frank
i asume its 2 pole as for it starting is that what i missed in ians post
thanks again to all for your help tho
thanks martin
25/07/2014 19:26:21
thanks ian i dont knowif its 4 pole or 2
how do i tell
thanks martin
24/07/2014 21:58:19
thanks phil freed up welght and running ok with out load but still dose it under load must be somthing else
will try post a photo it is a i xi l lathe the same as the one on lathes .co.uk
screw cutting made around 1936 its motor to drive shaft then shaft to pully to chuck
motor that came off origanaly was 3/4 hp ran ok till it went bang
checked bob weights and runnig free
thanks martin
24/07/2014 20:31:26
thanks peter
and every one else
i had a look inside to day an found the centrifugle weights were stuck open
but will put a switch on first before running her
thanks everone again for your advice owt machanical i can do but a loss with electrics
23/07/2014 21:50:01
thanks i will get one and fit it before i use it
thanks martin
23/07/2014 17:56:48
thanks emgee
i only tryed it with bigger fuse as dident want to damage anything till i got advice
my main feed is to 32 amp breaker thats why i tryed bigger fuse wire
so if i take the plug off an put to a dol starter switch or other it should be ok
thanks martin
23/07/2014 09:43:33
hi to every one great site and some great stuff
my problem if any one can help
i have a brooke crompton 1hp motor
on an ixl lathe it was a replacement when i switch the motor on it runs beautiful no noise very quiate but when i connect it up to the lathe ie put belts on
it blows the 13 amp fuse
i put a little bit thicker wire in the fuse and it starts ok made it about 16amp
dose it need a starter switch or simler as its on a plug
thanks martin
