Member postings for M J Ali
Here is a list of all the postings M J Ali has made in our forums. Click on a thread name to jump to the thread.
Thread: Which indexable thread cutting tools and chuck to buy?
18/04/2014 11:12:39
Brilliant!! I don't have to design a 127/100 changewheel in solidworks now, and hope the material I choose won't disintegrate in use. Hopefully I also have the full set of gears as well. And I can cut the correct pitch straight away too.
17/04/2014 18:30:59
Unfortunately, it has an imperial leadscrew, but as I'm only making visual prototypes at the moment, I figured that the pitch isn't critical at the moment. If I use taps and dies, then I'd be doing it manually with a tailstock die holder, I guess.
I'll keep an eye out for an imperial thread dial indicator as the leadscrew pitch is going to different afaik.
That's a really good point about being able to grind an hss bit down to enable it to fit into a tight hole for the internal threads. I think I'll have a go at grinding down the quarter inch hss stock next week and give it a try.
I bought a new toolpost as the supplied one was in pretty poor shape. No screws and worn out threads from generations of overtightening. I also figured it would be important to be able to do multiple operations without having to stop and adjust the height every time, so I plumped for the T1 quick change number from rdg. It seemed to be most similar to the ones on the three colchesters in the college workshop. It made sense to spend money on that as tooling is relatively replaceable by comparison.
Ultimately, I need to find a 127/100 changewheel to cut metric threads properly. Although I'm considering making one on the cnc machine at college. I have a slot booked for the beginning of May so I have a bit of time to do some research.
17/04/2014 15:47:43
Thank you all, for the encouraging posts and amazing information!
Sorry I haven't got back sooner, I've been burning the midnight oil at college trying to get as much done as I can before college closed for the Easter break. No workshop access now till Wednesday!
Ian, that's a great idea. I have a piece of quarter inch square hss tooling that I found amongst the debris in the lathe. I'll give it a try when I get back.
Bob, I'm going to be cutting threads into aluminium so it should be a bit easier. I did consider using regular taps and dies, but I need a finer thread than a M20 (a tap and die size I don't unfortunately have either).
It's reassuring to know that you've run a 200mm chuck before. I think I might need to take another link out of the belt at some point, as I do get slippage occasionally.
Bazyle. You're right those are the two chucks that came with the lathe and both came with internal jaws only. I guess that's why I thought the 3 jaw was a 3 inch as that seems to be the capacity it can grip around a rod.
The serial number on the jaws also don't match those on the body. Is this normal? I can't seem to find any information about it online. I was also told by one of the technicians that you had to be careful with things flying out of the chuck making me think it might need lapping?
Thank you Neil, I'm discovering what a great machine the AUD is. Even though it hasn't had the attention it needed, it has come back to life surprisingly well. 10mm seems to be a good size for the internal.
Would an 8mm with light cuts do the job as well, do you think? I'm thinking I'll be able to do a bigger range of internal diameters with it, or is it better just to get a the right tip holder for the job?
Bob and Tony. Unfortunately, there's no thread dial indicator. I did get a pair of old Baty dial indicators with a a stand from ebay. I have to honest, they're not great. Very sticky and one of them has a damaged gear which only allows half the travel. Still, they've been very useful. I didn't think to use them for screw cutting but it makes total sense to be able to clock up the travel.
Unless I can get a set of external jaws (if the serial numbering isn't relevant), I'll practice figuring out how to set up the 4 jaw chuck.
16/04/2014 12:45:26
Hi everybody
I'm new to this forum and to thread cutting and looking for some advice.
I'm a design student at the royal college of art and I'm trying to make some parts for a machine I'm making.
I'd like to thread some parts, mostly with an ID around 20mm. I'm considering indexable because I can replace the tips easily (although more expensive) when I break them(!) and don't trust my ability to sharpen a carbide tip to 60 degrees.
My buying options at the moment are 6 or 8mm shank sized kits from rdgtools (http://www.rdgtools.co.uk/acatalog/Indexable-Screw-Cutting-Sets.html) or individual tools. I was thinking the kits because they have both internal and external tools and a number of spare tips.
Chronos have separate int and ext kits but in a 16mm shank, too big for what I need to do, I think? (http://www.chronos.ltd.uk/acatalog/Sets_of_16_mm_Square_Indexable_Threading_Tools.html)
I can't afford to wait for 12mm shank kits to come back in at rdg, arceurotrade or chronos and at the moment would obviously rather spend a bit less.
Is it a false economy to buy a set rather than individual tools?
Does the shank of the tool holder (8mm vs 10 or 12mm) make such a big difference?
Does the type of tip make a huge difference? Generic A60, G60 vs pitch specific tips?
Unfortunately I can't really afford to make a mistake in terms of time or money just now, with the final exam and show rushing towards me.
I have a 1964 Boxford AUD, which I bought from the college a couple of months ago. It was being scrapped because laterly it had been in the wood workshop for 10-15 years where they just hadn't had the time to maintain it. It was still just about working but needed a lot of tlc because it was totally clogged up with wood dust. I stripped it down, cleaned, oiled, unseized it, changed belt etc and it now seems to be working fine. Well enough for what I need to do at the moment.
So this leads to my second question. The lathe came with a burnerd 3 inch chuck with only the external jaws. I'm finding now that it's a bit small for what I need to do. Chronos has a vertex 100mm chuck but would prefer bigger.
Does anybody have any experience mounting a 130mm chuck on an AUDII for instance? Does it actually go on?
Do I have to take the weight of the chuck into consideration and how will this affect the spindle and bearings? Will it wear them out, or mean that I have to do even smaller cuts?
Would it be better to got the 100mm vertex chuck or even one of the other ones: Sharp, Soba, Turntech, generic?
I'm fairly new to this so apologies for so many questions and if I've left out a ton of information.
Many thanks in advance
Mo
