Here is a list of all the postings Robert Staley has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford Industrial Stand Wiring |
01/03/2014 00:17:11 |
My circuit is a modifed version of one shown here: Worth a look, as it also contains very useful info about safety and ratings.
28/02/2014 23:21:14 |
I am glad you like it Adam, it has worked fine for 3 years. My album is now working:
28/02/2014 12:47:16 |
Hi Stephen, I have just joined the forum. Are you on the way to a solution or are you still looking? I converted an industrial stand from 3 phase to single in 2011. The Myford factory electrician told me I had to replace the Santon rotary switch with a rather expensive and ugly one from RS. This solution did not provide no voltage release. I didn't want to change the external appearance of the front panel, so I did it by replacing the contactor. Worked our fairly inexpensive I think, doesn't load the Santon switch much and provides NVR. I will add a wiring diagram if I can get "Albums" to work!
