Here is a list of all the postings David Frantz has made in our forums. Click on a thread name to jump to the thread.
Thread: New workshop - your recommendations |
26/01/2014 03:59:54 |
Do not underestimate the importance of good lighting. This from somebody that has done the lighting in his shop 3 times.
I have aver reservations about your approach to the floor. Ideally the floor should be a heavy slab of concrete at least 6" thick. This especially the case if you ever expect to install larger machines.
As as for electrical considerations, things are done strangely in the UK. I'm not sure I can help a whole lot but at the very least have individual circuits for your larger machines. This especially the case for large air compressors, lathes or mills. For safety always have the overhead lighting circuits separate from the machinery circuits. Machine mounted lights are another deal. Generally you want a sub circuit that is installed as part of the machines controls. This so that the machine is completely dead when powered down. This doesn't happen in reality all that much though. An alternative is overhead track lighting. For your flooring either epoxy paint or hard tile. Works stations can be made more comfortable with rubber mats or wooden slat mats.
Dont over do benches, storage becomes very important as you build up your shop. In some instance you need need something more like a counter top on a set of storage cabinets. Frankly this would not be unlike a kitchen.
Posted by John Coates on 30/04/2013 19:47:38: Started marking out the garden for the new workshop today. Decided I need to start so it might be done this year and I don't spend another winter looking at my freezing garage wishing I could be metal bashing It will be 12' by 8' internal. Double layered flooring laid cross wise over 50mm insulation on concrete over hardcore. Walls and roof will be 50mm insulation with log lap exterior (felt on roof). All walls and ceilings boarded out. Small windows looking west. Moisture and vapour barriers. What I want are your learned thoughts about anything else I can design in or should consider. So far from reading "shed" or "workshop" threads I have gleaned: - you can never have enough power sockets: I intend to run power from the consumer unit in the garage via a conduit to a smaller consumer unit in the workshop. This will have a lighting circuit and power circuits. All my machines (lathe, mill/drill, shaper) are converted to 3 phase from inverters so don't need a huge fuse rating (10A I reckon?) for this circuit. Other stuff (pillar drill, grinder, bandsaw) are single phase Can I have the machine lights (bench height) on the same circuit as the ceiling lights (probably fluoro tubes) ? - flooring: needs to be cleanable and durable, any suggestions? - layout: there will two 2' doors in one of the 8' ends. I consider this the "dirty" end as it is closest to the doors so easiest to sweep muck out onto tarpaulin or the like But what about swarf control? From the mill and shaper the blasted stuff flies everywhere so will reach all corners of the workshop unless I do something. Pointing the shaper towards the door is one possibility so the swarf flies that way! Maybe a perspex screen around the mill/drill? Any wall adjacent are not occupied by a floor standing machine will be benched Anyway those are my thoughts at this stage. Any other considerations or suggestions gratefully received John
