Here is a list of all the postings Simon Friend has made in our forums. Click on a thread name to jump to the thread.
Thread: Emco Compact 5 Leadscrew Bush Slipping |
22/11/2022 19:10:21 |
Problem solved with a bit of elbow grease The bush was stuck (accumulated detritus) to the handwheel so it was rotating when you turn the wheel. Tightened the grubscrew right up and applied some reasonable force to the handwheel and it came free. Seems fine now. |
22/11/2022 18:50:18 |
I can't find any more screws, and the manuals are no help. The only other thing I can come up with is that maybe there is supposed to be a part to lock the leadscrew from moving forward at the other end. |
22/11/2022 18:08:26 |
Hi, I'm currently trying to restore an Emco Compact 5 that had been stored out in the garage and needed de-rusting etc. I'm having problems with the leadscrew slipping. When you turn the handwheel, the bush rotates out of the back (see pic). Even if you tighten the grubscrew to the point of almost no movement, this still happens. Any ideas? |
Thread: Another Newb Question- Best cutting tool for tapers? |
10/01/2014 23:54:42 |
Should have mentioned I'm looking at the offsetting the topslide method.
10/01/2014 23:07:32 |
Having just started out, I'm somewhat overwhelmed by the amount of cutting tools out there for for various cutting projects. I was hoping that someone could advise me what the best type of tool is for turning tapers? I'm using an Emco Unimat 5 and am unsure if I have a suitable tool amongst the small selection I received with the machine after the auction. Thanks in advance, Simon
Thread: Emco Compact 5 Question |
10/01/2014 22:06:05 |
David, you are a star! I should have figured out there was a screw under the topslide, but sometimes it gets so you can't see the wood from the trees.
Many thanks, Simon |
10/01/2014 19:55:53 |
Hello everyone, |
