Here is a list of all the postings anthony bryant has made in our forums. Click on a thread name to jump to the thread.
Thread: Rollo Elf |
01/12/2014 18:52:35 |
The 8 mm drill is a tight fit which fits the tool post hole at each end equally well. but on the round bed Elf only on one side. |
30/11/2014 16:57:11 |
I have had a senior moment ! My second (electric motor) Elf has a round not flat bed. The slot for round tools in the tool post is not tapered (8mm ID) ,on the flat bed hand cranked Elf. but might be on my other one , a 8mm drill will only fit one way; when I have drilled out the broken retaining bolt I will be able to tell |
30/11/2014 09:54:10 |
Good idea ; I will try to cast a plug today.. |
29/11/2014 11:29:08 |
I bought another Rollo Elf as it came with two chucks (5/8 BSF). I am sure that the Elf was designed to fit Brown & Sharp No I or 2 ,tapped tools .The tool post has a slot for round tools, which is tapered |
04/01/2014 12:07:02 |
I have a Rollo ELF (hand crank, flat bed )the nose thread is 5/8 BSF .I think the taper is a Brown & sharp 1 or 2 . Sadly the lathe came without a chuck. Has anyone got a manual for the Elf. |
