Member postings for Stephen Houston 1
Here is a list of all the postings Stephen Houston 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Mystery bench top hacksaw
15/12/2013 22:15:26
Robbo
I have a full working version of your find
the motor is 1/4 HP, Drive pulley is 1" Dia, Driven pulley is 7", 3/4" wide flat belt, the dashpot has flow v/v were the hex plug is,
The right hand side has a spring operated holed up that resets the micro switch when pushed away from you and starts
the saw, the adjuster screw on the frame will switch the saw off once it has cut though the metal.
I have mine under the bench, I just put what ever i what to cut in the saw and walkaway.
