Member postings for K.J. Kroeker
Here is a list of all the postings K.J. Kroeker has made in our forums. Click on a thread name to jump to the thread.
Thread: Simulation of toolpaths in Fusion 360 - personal version
28/12/2022 22:25:33
Simulation works fine here.
Thread: .dwg and .dxf files
11/05/2022 22:31:09
If your desired dxf can be defined by one sketch in Fusion 360, you can generate the DXF by right clicking on the sketch in the browser and selecting save as dxf.
Thread: Replacement for thunderbird (emails)
03/11/2021 23:54:54
You can install Thunderbird on your new PC if you leave "S" mode. S mode allows only applications from the Microsoft store. If you leave S mode, you cannot go back - you will be in standard Windows 10 and able to run anything you like.
S mode is touted as a more secure solution since applications from the Microsoft store are thoroughly vetted by Microsoft.
Thread: Best way to do small production run?
25/01/2018 16:05:26
Exporting a DXF in fusion can only be done from the sketch menu - it's the last item in the menu. When you do so, splines are converted to polylines. You could also export a dwg file in the drawings environment and convert that to DXF in most 2D CAD packages.
