Member postings for Oompa Lumpa
Here is a list of all the postings Oompa Lumpa has made in our forums. Click on a thread name to jump to the thread.
Thread: What have you recycled today?
09/01/2014 23:01:22
Today I recycled nothing, but I did manage to finish my crucible tongs for my "foundry" which I will fire up tomorrow to make a start on all the scrap aluminium.
Thread: Would like to buy a threading tool
09/01/2014 22:54:43
It is of course the Ainjest high speed threading unit I am referring to. I do know the price of the Glanze tooling.
09/01/2014 22:05:29
Thank you very much for all that guys.
I understand your thoughts regarding the high speed Andrew but two things spring to mind, firstly - I am always wary of any product that you cannot find a published price.
Secondly, I really don't want to spend a fortune as it is not a massive job and I would like to see some small return. Going off the assumption that "if you have to ask the price you can't afford it" I would dismiss the idea out of hand. I quite simply cannot see any valid reason why a price cannot be published. Puts me right off.
I am going to order the tool and see how I get on. I will be ordering 60 degree tips and see what the fit is like. Then I will report back.
graham.
09/01/2014 21:08:22
I am looking to buying an "Indexing Threading Tool". I am looking at buying THIS ONE to be exact.
I am wanting to cut 5/8" UNF and M14 threads so theoretically I will be needing two different threading tips, which is fine. I will not be using any of my many HSS tools for this job.
Does anyone have any experience of this tool? Or any similar tools.
Thanks in advance,
graham.
Thread: Need a bit of Motor Advice.
08/01/2014 17:11:50
Well, all cleaned up and put back together - works great. I had a 1" bore Scotchbrite wheel in the "stores", it has seen better days but it will do for now. I will look around for replacements.
Trevor, thanks for the heads up on the switches, if I decide to get one it will be from Axminster. DaveB, although a great many industrial polishers use pigtails for easy mop on and off, there are some polishing machines, such as this one, which are designed to take a mop or wheel - usually of the Scotchbrite type - which have a substantial spindle and are designed to have the wheel fastened on.
Thanks everybody for all of the advice.
graham.
07/01/2014 21:13:59
Very very helpful, thank you for taking the time.
John you first - The 'ON' button of the starter does not always lock in the on position and you need to have a couple of goes sometimes to make it lock in. So as I have it in bits I thought I might replace it but I am not going to be throwing money at it.
Swarfy, very informative. The thing was just completely choked in crud so I have scraped most of it off and I will go over it with a stiff brush before I put it back together. The switch was fastened to a plate which was bolted across the pretty holes blocking most of it, I will fabricate something a bit more substantial and make some standoffs or something.
Pretty pleased with it overall, I didn't give much for it and it is going to make a terrific polishing machine. My ony snag is buying a mop for it, I have seen some really nice thick mops down at Chester tools so I will look into that but the spindle is 1" so there is no doubt I am modifying anything I get.
graham.
07/01/2014 16:59:50
So I 'won' a single ended polisher/grinder.
First thing is the starter, I was wondering if I could swap it out for one of those £10 replacements from That Auction site?
Next up is the fan. i cannot see what it does, apart from spin around? It is a totally enclosed motor (which runs lovely by the way) and there is a cover which sucks air in and blows it around but not anywhere useful that I can see. There is no way air can be circulated anywhere, not to my mind anyway.
As they say, a picture is worth a thousand words:
The starter mounts on the rear, over the fan cover.
graham.
Thread: Mill refusing to power up
06/01/2014 21:52:56
Posted by Russell Bates on 06/01/2014 19:43:00:
he just said he has 230v, which doesn't cover it, he needs to load the supply IMO - plug in a hoover or something just to be sure
- very remote chance but it only takes 2 seconds to test
I tried it in a couple of other sockets - not on the same circuit - with the same result.
In fairness, I have had an extremely busy day and this was not top of my list so I have sent an email off this evening. I am sure it will be responded to in due course.
Thank you all
Thread: HSS sharpening
06/01/2014 12:46:11
Posted by Bogstandard2 on 06/01/2014 11:40:53:
There is a large difference between grinding a lathe tool to shape and sharpening one.
Probably the wisest thing I have read in a while!
graham.
06/01/2014 09:14:24
Yes.
Any amount of advice here: British Blades
Not meaning to be controversial but if you want to know anything about grinding on linishers, these guys seem to be the experts.
Thread: Workshop Break in
04/01/2014 19:18:26
Posted by V8Eng on 04/01/2014 18:53:44:
Somebody once told me that "you keep a small dog to wake the big one who does the work"
Works for me!
My idea of "taking the dogs out" is to open the front door. But as you say nothing is foolproof. I am guilty of leaving outside doors unlocked - sheer forgetfulness - on more than one occasion
When the missus is away though, irrespective of the weather, I leave the back door into the yard open and then all the doors into the house open. This way if one of them wants to wee in the middle of the night they can just get on with it and not wake me up When the lady of the house is in residence though we all have to follow the rules!
(which involves a LOT of bolts and locks)
graham.
04/01/2014 17:19:49
Posted by Roger Williams 2 on 04/01/2014 17:04:08:
Yes, we used to have a neighbour with a big dog, trouble is it used to bark rather a lot, morning noon and night, f*****g thing !.So living next door to someone with 3 must be lovely.Dont get me wrong, I like dogs, but not the ones whos owners couldnt control or give a damn. Sorry for the rant
If I stand on a milk crate on my patio and crane my neck - I can just make out my neighbours.
And do not EVER group me with the FWits who quite simply should never be allowed ANY animal. I would be obliged.
And for the record, when the big ones bark I am bringing the shotgun. It is the little fella that is the noisy little git but I know when someone is at the bottom of the lane before they know where they are no matter what time it is.
graham.
Thread: Alarms and Diversions
04/01/2014 10:22:53
Posted by Davey J on 03/01/2014 19:23:32:
Evening all, just been reading this thread with just a hint of concern. Use lights, very spiky plants and make "safe" noises to scare the herberts away. Please do not think of pyrotechnics of any sort, it will end in tears. Your local Constabulary will take a very dim view of such devices (trust me, I am a CSI) **LINK** If they have decided to come in you will not keep them out. Make entry as difficult as possible and hope they break into next door's shed instead - harsh but that is where society is at present. P.S. Make sure the hinge side of the door is as secure as the lock side. So easy to snap wood at the hinges and leave the expensive bullet proof padlock in place. Also secure the roof firmly, on most sheds these pull up and off with minimal effort!. Sorry to be so gloomy so early in the New Year,all the best. David
Good morning David, the latter part of your advice is very sound and actually, as creative people, we can easily fabricate bolts that go into the door jamb on the hinge side and then into pockets on the door itself, this way even if the hinges were ground or cut off the door would not open.
However, I am a bit concerned at the link you posted to the BBC website highlighting the case of three men who were charged with manufacturing a firearm.
This case ended with aquital of all three defendants. In my opinion, having a little knowledge of the case, the problem here was not only did the defendants (well, one of them anyway) actually place the shotgun blank into a tube (very bad idea) but that he actually used a shotgun cartridge and not a blank bought "off the shelf".
The difference was between a charge of "Manufacturing a Firearm" or using a Signalling Device - Poles apart. The type of signalling device being copied was the one sold by Henry Krank as shown. Also on Amazon UK if you do a quick search for Alarm Mine.
Sorry to be pedantic but I try to stick to the facts and the British Bonking Corporation report fewer and fewer of these as the weeks go by - facts that is. I am certain they only reported the "Harrowing Story" as opposed to the full story. What were these boys doing on the property? Not once but by their own admission multiple times? Were they charged with anything? (the answer is no by the way) Were they "given advice"? No, But God Forbid a homeowner tries to repel an intruder. We have a serious attitude problem in this country and those people we the taxpayer pay to do our bidding and keep us safe are no longer value for money. That is not a whinge, it is a fact sadly.
Thread: Evolution rage circular saw
03/01/2014 22:13:59
Right then, tomorrow I am going to give this a go and report back. I have a fine kerf blade so I will try that first.
graham.
03/01/2014 21:12:43
I have read a number of posts extolling the virtues of this saw. My question is - Is it the Saw as a package? ie. the saw and blade or is it the blade itself that is the "revolution"?
I was thinking of just buying a blade and fitting it to one of my circular saws. Would this work or is there some special feature to the saw itself?
I would like to cut up quite a bit of aluminium plate and bar stock.
Thanks,
graham.
Thread: Calculating volume in metric
03/01/2014 19:07:45
Posted by NJH on 03/01/2014 17:08:25:
Hi Roy
| "and measured them as 2 metres 4inches"
Guilty I'm afraid !
I wouldn't dream of mixing measurements in the workshop but must admit to doing so on D-I-Y projects around the house. Its more a matter of swinging around on top of a step ladder and finding the line on the rule that aligns with the edge of the thing being measured. For instance 100in + 5cm (as shown on the rule) lines up exactly and I can remember this to note down. The correct measurement is of course 2550mm or about 8ft 4 3/8in. Not easy to find on an extending rule!
Norman
I buy most of my rules and tapes from either the US or Germany. That way at least they are one or the other. I cannot cope with this mix of metric one side Imperial the other. Digital Calipers and micrometers are just terrific, easy to swap between the two.
graham.
Thread: mini Bandsaw, or mini Scroll Saw ??
03/01/2014 17:42:11
I have been following this thread with some anticipation. I was hoping that someone would have come up with an ideal model of small bench top metal bandsaw that I could buy myself!
Drat!
03/01/2014 17:04:39
Posted by Mark P. on 03/01/2014 14:43:39:
A big dog helps!!
Mark P.
Three are better though the Westie loves Postmen. Can't seem to manage a whole one though
graham.
03/01/2014 16:32:22
The National Mobile Phone theft register and the national crime unit for mobile phones is headed up by one (ONE) Detective Constable who is a terrific guy actually and he is fighting the whole thing, with essentially, no budget!
When he can get an operation going he enlists the help of others in Police forces around the country and frankly, the guy is one of those people who genuinely should receive a New Years honour. It is a formidable task the man has. If you had any idea how many mobile phones just one of the well known "we buy any phone" organisations gets sent every week and has to put to one side because they are on the stolen register you would be stunned. In fact, you would think I was making it up.
I cannot emphasise how important it is to register as many of your electronic belongings as possible on the register. It is getting to the point where I believe Insurance companies will require it, it would go some way to stop fraudulent claims too and in turn slow the constant rise in premiums for the rest of us.
What you need to do is get the Police to come round and mark up all your gear with "Smartwater". It is almost like everything has a DNA fingerprint registered to yourself. Call your local Crime Prevention officer.
graham.
03/01/2014 13:26:38
"I personally think a balance needs to be struck when securing a workshop. You want to make sure it is secure so a passing tea leaf doesn't make easy work of your locks and is in you workshop in a matter of seconds but likewise you don't want it secured like Fort Knox and make the thief think it is "really worth his while" to get in because anything with this much security must be good! "
And, frankly, if you make it too much of a pain in the Ass you will inevitably, over time, stop carrying out some of the locking and securing procedures.
It is inevitable.
graham.
