Member postings for Loose nut
Here is a list of all the postings Loose nut has made in our forums. Click on a thread name to jump to the thread.
Thread: Henry Greenly's 1933 design for the Model Engineer 1" scale traction engine
02/10/2015 11:53:12
I am looking for drawings or the ME editions covering this topic...
any ideas please ?
Thread: Large vertical engine - help with I/D or origin please
17/03/2015 12:15:50
Posted by thomas oliver 2 on 16/03/2015 18:53:11:
I note that the feet of the standard are tapered and the legs wide spread. It appears that the standard may have been adapted from say a Stuart 7A and split and splayed out to fit a diiferent base. It looks like a Bitza.
I am inclined to disagree on the Stuart standard thoery
heres a Stuart number 7A standard........
stuart 7 standard
And here's the one from my engine........
unknown vertical engine
As you can see although they are mildly similar they are not the same when you look up close in many ways.
17/03/2015 11:44:01
See attached link relating to working small engines and some quotes...
"small "workshop" steam engine built to run small power users back in the day.It is a little larger than one inch bore and built very well.I believe it has a specific function based on the design of the cast bed.It stands ten inches tall with a 4.500 diameter flywheel"
For very small power users..sewing machines,jewelers lathes and buffing arbors small engines like this were common.They were the smallest size on the far end of the power spectrum.Sipp was a well known manufacturer who made steam engines for commercial power.Even Stuart made engines in the early days that drove commercial generators and centrifugal pumps.
16/03/2015 17:15:18
Posted by roy entwistle on 16/03/2015 16:14:22:
Just my unqualified opinion But bolts holding the column to the base instead of studs too few ( in my opinion ) studs holding the cylinder cover and the valve chest There appear to be bolts again holding the bearing caps so I would suggest not an apprentice or an exhibition model from a manufacturer I am open to be shot down
Roy
The bolts holding the column to the base are not original in my opinion as the don't match either the studs or bolts elsewhere . The engine may have had some restoration work done in the past...
Do you agree it may have been an actual working engine ?
16/03/2015 14:45:12
. I acquired this rather large and heavy engine at the weekend and paid £100 for it.
Its very heavy (10kg) stands almost 10" tall (excluding wooden base)
Looks like a 1" bore with 1" stroke and the flywheel is 6" diameter and 3/4" wide.
The base casting is huge and looks industrial although no visible markings or plate.
Its been suggested that its a Victorian workshop engine used to power small bench tools.
Another thought that its an apprentice piece or an exhibition model made by a full size engine manufacturer.
Any help guidance and opinions would be appreciated.
Edited By Loose nut on 16/03/2015 14:54:32
Thread: meddings
21/04/2014 00:03:23
Pardon my ignorance but I have some old but good British made 3/4 x 10tpi BSW taps and would sell one or two ...are these what you are looking for ?? Or is acme a different thread. ???
Edited By Loose nut on 21/04/2014 00:06:56
Thread: Modular 3/4 inch TE info required
23/10/2013 11:04:38
Mark
message sent to you wink 2
regards
Karl
02/10/2013 22:21:46
Full set of drawings now aquired...many thanksface 1
Thread: colouring brass
30/09/2013 14:09:51
Try Liver of Sulphur (avaialble on ebay) small doses diluted with water ages. brass & copper..
28/09/2013 00:18:32
I have recently aquired a modular 3/4 Traction engine that I believe was built from ME magazine features in the early 1980's....
Can anyone tell me any more about these engines and how many known to exist ??
Does anyone know where can I get copies of the original plans please ??
