Here is a list of all the postings mick70 has made in our forums. Click on a thread name to jump to the thread.
Thread: clarkson tooling and cutter grinder mk 1 |
17/07/2015 07:59:22 |
that bedroom workshop is a great site. |
16/07/2015 16:55:40 |
cheers for replies. whats issue is stent article in? club as copies going back years. |
16/07/2015 11:47:15 |
have just aquired a mk1 clarkson for scrap value as cabling had all been cut off before going into storage 10 yrs ago. all worked ok before though. still all in good nick but didn't meet safety rule's coy were demanding. am struggling to find downloadable manual, only one's i can find start at £35. as anyone got one they e=mail me pls? |
Thread: boy designing workshop, help pls. |
14/07/2015 16:42:31 |
thanks for replies he as had great fun looking things up and deciding what we need. even more so since big sister's boyfriend gave him an old laptop, he as now got folders with pics in. now need to find couple of spare aircraft hangars and get 6 numbers up. Edited By naughtyboy on 14/07/2015 16:43:05 |
09/07/2015 18:43:45 |
will have the money as he is designing our lottery win workshop. as also added steam engine to his list only don't think he means model. |
09/07/2015 18:16:31 |
thanks for replies he is looking up bit's he doesn't recognize on my kindle. get feeling i'll have to buy couple of aircraft hangars first.
he as added biscuit barrel with choccy hob nobs to list.
09/07/2015 11:04:41 |
my 7yr is trying to design a workshop for if we have that win. and as asked me to ask people what they have/do. will list what he as so far from looking rd our shop and at model eng club we go to. lots of space lots of plugs and lights. benches with storage storage 2 lathes ( we have clarke and s-bend 9" 2 drill presses 1 drill press set up with tubing notcher. milling machine. tool cabinets ( roll cabs) welders kettle.
anyone like to add to his list?
Thread: What did you do today (2015) |
05/07/2015 18:02:23 |
working on design for tadpole recumbant bike that requires short crank arms. not prepared to pay silly prices dealers want especially as need different sizes to try out so built jig for drilling old crank arms to find right size. cheaper to buy set of left and right handed taps than it is to buy a cheap set of arms. |
Thread: instructions for steaming up |
01/07/2015 16:26:59 |
great thanks
01/07/2015 07:59:22 |
does anyone know where i can get set of instructions for steaming up an engine? want to be able to memorise it/ keep handy as ref, as due to my shift pattern's don't get to get club on lot of running days. and tend to forget in between times. cheers |
Thread: sb chuck on clarke lathe |
26/06/2015 16:42:07 |
got fair few chucks to go 9" sb lathe i bought. now planning on keeping my clarke cl430 for a while as got bits that can't easily swap over. cl430 as mt4 spindle would it work making an adaptor mt4 taper with the sb thread on end so i can use chucks faceplates etc from sb unless i can buy one ready made. as cant afford to replace bits i use for cl430 at moment, and youngest two are wanting to learn bit's on lathe so rather use cl430 for that.
Thread: square headed bolt |
25/06/2015 05:59:12 |
Sorry haven't replied away with work and internet hit and miss. Will measure bolt size Sat when I get back.
23/06/2015 17:52:08 |
need to make new bolt for steady on my sb 9". it's a square head so will need to use 4 jaw. what i need to know is am i better running file over corners to rd of slightly so i don't damage cutter or won't it matter? |
Thread: adjustable reamers |
19/06/2015 09:39:41 |
guy at work as set of ba reamers in loft at home that were his dads. looking at up sizes they cover i will be able to get job done. said they are like new in wood box say's i can them for tenner.
thanks for help |
18/06/2015 14:47:22 |
had thought that. but was hoping not. |
18/06/2015 14:35:49 |
need to get an adjustable reamer that does 5.5-6.5 sizes for a little project. can find 6mm up but not what i need. where you guy's buy from? cheers |
13/06/2015 15:58:43 |
Posted by Speedy Builder5 on 13/06/2015 15:08:03:
Naughtyboy - most motors can be reversed, just a bit more difficult if the motor has been installed in the under cabinet. Won't you want to run the motor in reverse sometimes anyway ? I use reverse quite a lot when screw cutting metric threads with the imperial leadscrew. Use it to reverse out after screw cutting with no cut on.
prob is need it turning other way to be able to cut. guy from club that does electrics is away at moment, he did say when i get motor fitted he will come up and wire it up to the dewhurst type switch i have for it. but you know what it's like when you get new toy. it runs above the and to rear of head unit. |
13/06/2015 14:33:11 |
fitted motor to southbend 9" only prob runs wrong way. not best fitting but planning on complete new stand for it and wanted to get it up and running so i can see what else i need to build into stand then will redesign mounting as running step pulleys on it and will need 3rd set to get speeds down for screwcutting. guy who had it before me had smashed small sect of seperate pulley and sold shaft that held the big pulley and motor for it. made mistake of building stand for my other lathe before it arrived and regretted it for 2 yrs till i built purpose made one for it. |
Thread: Spot Welder |
29/05/2015 19:32:20 |
can you buy single digital copies as wouldn't mind having article. oh and dismantled loads of microves mainly for the magnets to use when welding with no probs Edited By naughtyboy on 29/05/2015 19:32:40 |
28/05/2015 08:31:56 |
going out in bit to start tidying up southbend 9" model c i bought. it is in good nick but been stored for few years so needs cleaning. also need to fit motor to it and sort out the bits that came with it then at some point make 3c collet holder for it. and do backing plate for er16 collet chuck i aquired from guy at club.
