Member postings for james karran
Here is a list of all the postings james karran has made in our forums. Click on a thread name to jump to the thread.
Thread: Napier Deltic
05/04/2013 10:53:56
Drawings no but there's a full scale one sectioned in the National Railway Museum and a 9cyl model version in the collection as well.
Thread: Toyo ML-210 (Manix ML-210 / Proxxon PF-230) bearing question
07/03/2013 09:06:36
Ha! I'd been to that site several times since buying the thing yet somehow I'd missed that page. Thank you.
And thank you Ketan for the detailed info on the bearings. I think I now have all I need to strip it and ensure that what goes back in is as good as what comes out.
06/03/2013 11:09:47
Thanks Clive, it was really the higher precision and lower radial clearance variants I was having trouble finding. Of course it may turn out to be a bog standard bearing Toyo spec'd in which case you're right, there's loads of choice. I'll have to bite the bullet and pull it apart completely to find out. Fingers crossed it's that easy and cheap!
06/03/2013 08:58:44
Thanks. I've had no joy finding an online stockist of high precision 6003Z bearings, I'll have a look at Arc Euro Trade. I did wonder why they're not rubber sealed units, presumably it's to run cooler so radial clearances in the bearing can be minimised (especially since there doesn't appear to be a pre-load spring)?
There's a drawing of the spindle in the manual, there's no pre-load washer or spring shown but it is just the spindle and bearings out of context, I guess I'll see what the arrangement is when I get to it.
The issue I've got with the milling quill is purely related to the quill and the fact it rocks noticeably unless fully locked down, the other slideways were locked and the work secure. I can't really see where the free play is coming from, I'd have thought there'd be a point (while tightening the clamp) where the quill was just free to slide and the rocking play was minimised but it doesn't seem to work quite like that. I guess I need to look a bit closer, I suppose it's possible there's a chip or some other debris lodged in there.
05/03/2013 10:12:36
Hello. Please forgive any incorrect/inaccurat terminology, I'm pretty new to this
With an eye to some tabletop engineering and potentially some watchmaking if it/I prove capable I recently bought a used ML-210 with the extra milling head and a pile of extras. Generally it's in good condition and I'm pleased with it but I do have a couple of questions the excellent user manual doesn't cover...
The spindle nose bearing is a little notchy and noisy, it improves a little when pre-loaded and there's no discernable free play but I suspect it's affecting surface finish. If it's a straightforward job I may as well replace it. The spindle bearings are both 6003Z, only one face of the rear one is currently visible and there don't appear to be any tolerance/quality markings on it (there's a makers mark but I forget who it's from).
Perhaps sombody could point me at a suitable tollerance/quality/grade of bearing for a machine like this, I'd like to replace like with like if I'm going to do it but I'm rather overwhelmed by the options available! Also, withdrawing the spindle is not covered in the instructions, has anyone done this with an ML-210, it wont push out by hand so I'm presuming I need to carefully press it out or pull it with a threaded drawbar. I'm a bit nervous of damaging the hollow aluminium headstock casting.
My other question (I'm sure there'll be more!) relates to the milling/drilling head. This is adequately rigid when the z-axis clamp is done up but rocks significantly when it's not done up making drilling uneven material (of center roundbar for example) or plunging an endmill unreliable. Is anyone familiar with the machine, does it sound like there's a guide ring or shim missing (or worse)? It doesn't appear to be worn or abused in any way, perhaps it's just a design limitation?
Thanks in advance for any help, James.
