Here is a list of all the postings choochoo_baloo has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford ML7 mandrel speeds |
20/11/2014 20:08:57 |
Thanks for the info. I am keen to up the mandrel speed. I have original Myford reservoir headstock oilers fitted - do they need to be set to fully open? Would it be feasible to replace the mandrel bearings with something capable of higher speeds, say graphite or phosphor bronze (though I am not sure of the ideal material!) ? |
20/11/2014 17:55:00 |
Hello all,
I am a newcomer to model engineering. I have good condition ML7 with all the standard tooling and have been playing and practising lately. One issue has arisen which I would really appreciate some help with please. I am getting lacklustre performance from turning and facing, and even drilling from the taitstock. This is most noticeable on brass. I am convinced that this is due to the rotational speed of the mandrel being far too low, even at the highest belt settings. I have the original Metropolitan Vickers 1450 rpm motor with 1-7/8" dia pulley fitted. According to Bradley's Myford Series 7 manual, thus all gives a highest mandrel speed of 640 rpm. Now from checking a basic spindle rate reference table: http://www.southbaymachine.com/setups/cuttingspeeds.htm#Quick%20RPM%20Table for the 1/4" dis brass that I was practising with, 3200 rpm is the approx. rpm I require.... !! Hence this is what I'm planning to do to increase the mandrel speeds available: swap the 1-7/8' motor pulley for a Super 7 4-3/8" and 1-3/4" dual puller. This bigger pulley brings me up c 1500 rpm. Possibly buy a new faster motor? What have other ML7 owners done to tackle this issue? Thanks in advance for any help. Matthew |
