Member postings for Jim O'Connell 1
Here is a list of all the postings Jim O'Connell 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Amadeal Lathe
17/09/2016 13:31:12
I got in touch with Amadeal and they said the motor was still in warranty.>>
I returned the motor and the circuit board to be checked out and it arrived back yesterday.>>
10 out of 10>>
Now I just have to put it back together!!! Just as well I took lots of pics.>>
Thread: ER Colletts - will they hold my plug?
06/09/2016 09:59:33
Lots of ways to approach this problem. Thanks for all the advice guys.
05/09/2016 10:39:31
Posted by Frances IoM on 05/09/2016 09:56:03:
Jim to return to your original post - have you got any nuts for the thread (is it a standard thread eg M20 - do you know what the thread is?)
It is a a standard 1.5. The problem I'm having is griping the 4mm head of the plug and getting it to turn true.
Forgive terminology I'm new to all this!!!
05/09/2016 09:12:25
Posted by SillyOldDuffer on 02/09/2016 16:38:08:
Posted by Jim O'Connell 1 on 01/09/2016 19:41:52:
What I want to do is put a spring recess 10mm wide by 1mm deep in the plug that screws down on the spring.
I have the 2 flute end mill to do the job. Just looking for a quick way to center the plug in the chuck or whatever.
Have a good few to do!!!
Hi Jim,
Is this what you are trying to produce? If so, how deep in mm is the head that needs to be gripped?
Ta,
Yes. This is what I want to do. The head of the plug is 4mm X 25mm and the treaded part is 15mm X 20mm long
02/09/2016 15:42:26
Posted by JasonB on 01/09/2016 19:48:49:
All three of these could be solved by Frances' method
Whats the Frances method???
01/09/2016 19:41:52
01/09/2016 17:18:08
I am thinking of getting an ER collet for my mini lathe. I am new to lathes so please bear with me.
I have a 20mm stainless plug and the head is 25mm.
I want to grip the 25mm head and machine the screw part
Problem with the 3 jaw chuck is it is hard to center the plug.
Would the ER collet help!!! Any advice please
01/09/2016 15:02:23
Getting back to my problem. I have contacted Amadeal and they say they I am still covered.
So by agreement I am sending them the motor and the circuit board to be checked out.
Fingers crossed, and I will let you guys know how I get on.
30/08/2016 15:29:34
Posted by John Rudd on 30/08/2016 10:23:45:
Checking the control board is relatively simple,
Disconnect the cables from the board that go to the motor, these should be connected to the A and A+ spades on the pcb if its the KB style controller, else follow where the leads are terminated on the board...
Can I use a Multimeter to check?
30/08/2016 09:14:55
Did not sleep well last night. Turning lots of motors and things over in my little sleepy head.
OK. lets start at the beginning of this problem.
1) Like Niel was saying I have run the motor too slow to the extent that the motor stopped before I hit the STOP button.
2) When the motor stopped last week while working it not not going fast as I was cutting a piece of stainless with a hacksaw. Slow speed and working the saw over it.
3) Then there was the bang and some smoke and the lathe stopped. It blew the lathe fuse, the light over the lathe, the garage fuse and the house fuse all in one go.
4) I am now thinking that the lathe control circuit board let in the AC 220 and cooked the motor. Just a big thought!!!
If this is the case, I will also need a new control board at another £100 or so.
How would I check the control board before fitting a new motor and maybe blowing the new motor on first switch on!!
29/08/2016 19:57:26
It's not that it's cheaper. In fact, it's about £20-£30 more expensive.
Where I am coming from is, is it a better system then the brush motor originally fitted? Will the new brush motor pack up again and I am £100 down
29/08/2016 19:17:24
Oops. Well we all make mistakes. I do remember when I got the lathe almost stalling it as I was turning some stainless and went too slow.
OK. Should I buy a new motor at about £98 or maybe go the brush less 24v motor in the article I posted.
29/08/2016 15:13:11
Was looking things up and found this!!! Anyone tried it???
https://letsbuildone.wordpress.com/mini-lathe-motor-upgrade/
29/08/2016 14:40:55
Just checked and lathe was bought on 10th Feb and the electrics only have a 6 month guarantee!!!
29/08/2016 14:32:27
There was a bang and some smoke. I have taken the lathe out and tested it in a vice. Another bang, smoke and blown fuses
29/08/2016 12:50:42
Hi Guys. I bought a mini lathe just over 6 months ago and the 450w motor has burnt out.
Is there a better replacement motor out there, instead of buying the same again?
I'm new to lathes but getting to like them apart from this problem.
Thanks in advance for any advice offered.
Jim
